  3. Virtuoso Video Diary: Multi-Technology Simulation—The Good…
Udit Rajput
Udit Rajput
ICADVM18.1
ADE Explorer
Spectre
Custom IC
IC6.1.8
ADE Assembler
MTS
Virtuoso Video Diary: Multi-Technology Simulation—The Good has Changed for Better
3 Oct 2019 • 2 minute read
If you have multiple circuits designed with different process technologies on a single chip, it seems very likely that you have used our Multi-Technology Simulation (MTS) feature to simulate them. And, if you have used it recently, you would have noticed that the Multi-Technology Mode option through which you used to enable the feature is no longer there on the Choosing Simulator form. Where has it gone? Well, it has not only found a new address, but a new name too.
New address: MTS Options Form
New name: Enable locally scoped models and options (MTS)
We have also changed the way MTS settings are saved. Earlier, they were saved in a configuration view, but now the MTS settings are saved in the test state, thereby enabling you to set up MTS for each test independently.
Model files and process parameters can now be locally scoped at the instance level. Earlier, this was possible only at the cell level. That makes the MTS feature truly local, justifying its new name. By default, these settings are copied to the instance from its cell. You, however, have the flexibility to define different model files and process parameters for an instance from those defined for its cell.
With all the changes MTS has undergone, you would certainly agree that an otherwise-good feature has only changed to become even better.
  To know more about the other enhancements made to this feature, watch the Multi-Technology Simulation (MTS) with Local Scoped Models video on Cadence Support portal.
  • Multi-Technology Simulation (MTS) Flow with Local Scoping for Instance in ADE Assembler
  • Using Spectre Multi Technology Simulation (MTS)
About Virtuoso Video Diary
Virtuoso Video Diary is an online journal that relays information about Virtuoso videos that are available in the Cadence Online Support Video Library. Hundreds of interesting videos on a wide variety of new and exciting Virtuoso features have already been created. Virtuoso Video Diary brings you direct links to these videos and other related material, on regular basis. Click Subscribe to visit the Subscriptions box at the top of the page in which you can submit your email address to receive notifications about our latest Virtuoso Video Diary posts.
Happy reading!
Udit Rajput
