  3. Virtuoso Video Diary: Reusing Variables through CSV Export…
Rashmi G
Rashmi G
Analog Design Environment
custom/analog
Explorer
Analog Simulation
analog
ADE
Assembler
ADE Assembler
Virtuoso Video Diary: Reusing Variables through CSV Export and Import
5 Apr 2018 • 2 minute read
Do you have some specific variables in a test and wonder if you could have a way to reuse them globally for all tests or locally in a particular test? You will be glad to know that Virtuoso® ADE Assembler and Virtuoso® ADE Explorer offer you a simple and time-saving solution to perform this task. You can now export variables in a CSV file and then use the same file to import them as global or local variables in any session.
The animation below gives you a glimpse of the process.
CSV Export
By default, the exported CSV file is saved in the same directory from where you launch Virtuoso. After you’ve exported a set of variables to the CSV file, you can further customize this file to change variable values or delete, enable, or disable any variable.
The interesting part is that one CSV file can solve multiple purposes – you can reuse the variables globally by importing the CSV file into the Global Variables section in ADE Assembler, and, you can import the variables locally for a test in ADE Explorer.
To know more about this feature, view the Export and Import Variables in the ADE Assembler video available on Cadence Online Support. Click the video link now or visit Cadence Online Support and search for this video under Video Library.
  • User Guide
      • Exporting Global Variables to a CSV File
      • Importing Global Variables from a CSV File
      • Exporting Design Variables to a CSV File
      • Importing Design Variables from a CSV File
About Virtuoso Video Diary
Virtuoso Video Diary is an online journal that relays information about Virtuoso videos that are available in the Cadence Online Support Video Library. Hundreds of interesting videos on a wide variety of new and exciting Virtuoso features have already been created. Virtuoso Video Diary brings you direct links to these videos and other related material, on regular basis. Click Subscribe to visit the Subscriptions box at the top of the page in which you can submit your e-mail address to receive notifications about our latest Virtuoso Video Diary posts.
Rashmi Girdhar
