  3. Day 1 Track Summary: CadenceLIVE Silicon Valley 2026
Vinod Khera
Vinod Khera
CadenceAI
chiplets
CadenceLIVE2026
3DIC
AIinEngineering
Semiconductor
SystemDesign
DigitalDesign
ChipDesign
DesignAutomation
verification
15 Apr 2026 • 6 minute read
From Vision to Execution — AI-Driven Semiconductor Design at System Scale
Day 1 at CadenceLIVE Silicon Valley 2026 unfolded as a clear narrative arc across its technical tracks: what began as a vision for AI-enabled design quickly matured into a detailed, execution-focused blueprint for building next-generation semiconductor systems. Across morning and afternoon sessions, the industry’s direction was unambiguous—AI is no longer an auxiliary capability in EDA; it is becoming the organizing layer for design, verification, and system optimization.
Morning Sessions: Scaling AI Through System-Level Design Discipline
The morning tracks established the foundational shift underway in semiconductor engineering: traditional siloed optimization approaches are insufficient for the scale, power constraints, and architectural complexity of modern AI-driven workloads. Instead, intelligent automation and system-level co-optimization are emerging as core design principles.
A major focus was AI-driven physical implementation, where optimization is increasingly treated as a continuous, data-informed process rather than isolated tuning steps. Design flows are now leveraging historical project data to guide floorplanning, placement, and constraint tuning across iterations. Techniques such as replay-based optimization and smart model selection are enabling teams to reuse learning across designs, reducing iteration cycles while preserving quality of results.
In power integrity and signoff sessions, the growing dominance of IR drop, thermal, and reliability constraints in advanced nodes was highlighted. Adaptive power grid reinforcement strategies demonstrated how localized augmentation can reduce voltage drop while controlling timing impact and runtime overhead. The emphasis is shifting toward explicit tradeoff management between electrical integrity and parasitic sensitivity, enabling more predictable closure paths.
Verification at chiplet and system scale underscored the industry’s shift toward abstraction and reuse. Parameterized model generation, slicing strategies, and hybrid formal-functional coverage frameworks are enabling verification closure at scales that were previously computationally prohibitive. The emerging emphasis is not just coverage completeness, but measurable, risk-aware signoff tied directly to specification intent.
In mixed-signal and analog flows, simulation acceleration and optimized solver strategies addressed long-standing bottlenecks in regression runtimes. Meanwhile, layout-aware migration techniques and topology recognition are reducing manual effort in node transitions and analog reuse.
Across packaging, PCB, and thermal design, automation and reuse emerged as dominant themes. AI-assisted thermal exploration and structured via replication techniques demonstrated how previously manual, iterative processes can now be handled through data-driven optimization, improving both turnaround time and consistency in dense system designs.
By late morning, several cross-cutting signals had clearly emerged: AI-powered EDA is now a necessity, verification must scale alongside system complexity, and ecosystem-level alignment across foundries, IP providers, and EDA vendors is becoming a decisive factor in engineering success.
Afternoon Sessions: AI Moves from Optimization Layer to System Orchestrator
The afternoon tracks marked a decisive transition—from AI as an optimization aid to AI as an active orchestrator of design decisions across the full lifecycle.
In implementation and signoff, reinforcement learning–based design space exploration enabled efficient navigation of high-dimensional constraint spaces in advanced nodes. Replay-driven learning systems allowed optimization knowledge to persist across runs, making late-stage ECOs more targeted and computationally efficient. The result is a shift toward AI systems that actively guide convergence rather than passively assist tuning.
Verification sessions introduced increasingly agentic workflows. Autonomous verification agents are beginning to manage structured front-end tasks, while AI-assisted formal methods are improving accessibility and adoption across engineering teams. Schema-aware log analysis and intelligent debug frameworks are significantly improving signal extraction from large-scale verification runs.
Hardware-assisted verification continues to scale in parallel, with cloud-based elasticity and hybrid analog-digital-RF environments enabling realistic system-level validation. The direction is clear: verification is evolving into a continuously learning, adaptive system that responds dynamically to design complexity.
In custom and analog design, precision and statistical confidence are becoming first-order constraints. GPU-accelerated Monte Carlo analysis, high-sigma yield estimation, and layout-aware circuit optimization are enabling more robust design decisions earlier in the flow. These techniques are increasingly integrated with structured, parameterized design frameworks that improve reuse and iteration speed.
System-level and chiplet architecture tracks emphasized the complexity of multi-die integration. AI-driven signal integrity optimization, multiphysics co-simulation, and reliability monitoring are converging to address the challenges of heterogeneous integration. Emerging interoperability standards and predictive thermal technologies—including advanced cooling paradigms—highlight the importance of electrical, thermal, and mechanical co-design.
Meanwhile, cloud and infrastructure sessions reinforced the reality that EDA is becoming a cloud-scale workload. Modern design flows are increasingly dependent on elastic compute, bandwidth-aware architectures, and cost-optimized simulation environments to keep pace with AI-era design complexity.
In design IP and processor innovation, composable architectures and AI-optimized subsystems are shaping next-generation silicon. Chiplet interoperability, secure-by-design frameworks, and AI-tailored DSP architectures are defining a more modular and scalable approach to system design.
Cross-Track Confluence: A Unified Engineering Paradigm
Despite the diversity of topics, the tracks converged on a consistent architectural narrative:
  • AI is embedded across the entire semiconductor lifecycle—from design exploration to verification and signoff
  • Chiplet and multi-die architectures are redefining system boundaries and design methodologies
  • Verification and simulation are evolving into adaptive, data-driven systems rather than static workflows
  • Multiphysics and cross-domain co-design are now central, not peripheral, to system success
The industry is no longer optimizing individual stages of the flow. Instead, it is converging toward unified, continuously learning design ecosystems.
Closing Context: A Live Engineering Ecosystem in Motion
More than a conference agenda, the technical tracks functioned as a real-time reflection of production-scale engineering challenges. Every session emphasized deployable methodologies, measurable tradeoffs, and system-level execution rather than theoretical constructs.
As the day transitioned toward the expo and networking sessions, the intensity of technical discussion gave way to reflection—but the underlying message remained consistent. Semiconductor design is entering a phase defined by intelligent automation, cross-domain integration, and AI-native workflows that operate at system scale.
The anticipation in the room was tangible. And as winners were announced, it wasn’t just applause—it was a shared celebration of innovation, persistence, and engineering excellence. Congratulation to
Avinash Eega (NVIDIA) for winning the #CadenceLIVE Functional Verification Software Track Best Presentation Award for “WIZARD: Agentic AI-Based Verification Debug with Verisium SmartLog and APIs.”
Giuseppe Michetti (LintrinsIC Semiconductors Inc.) for winning the #CadenceLIVE Accelerated PCB & IC Packaging Analysis Track Best Presentation Award for “Integrated SOI X-Band Radar Switches.”
Kevin Yee (Samsung Semiconductor) for winning the #CadenceLIVE Design IP Track Best Presentation Award for “Samsung Chiplet Ecosystem – Accelerating Solutions.”
PCB packaging track winner is Nagaraj Shanmugam from Etched and Osamu Nakanishi, from Renesas is the winner for AI for Implementation track.
These recognitions reflect not just standout presentations, but the broader spirit of the event—where real-world engineering challenges meet innovative, production-ready solutions.
Day 1 with directional clarity: the future of semiconductor engineering is being built as a unified, adaptive system where design, verification, and infrastructure evolve together.
Stay Tuned for More LIVE Updates On Day 2 from CadenceLIVE Silicon Valley!
