  2. Data Center
  3. AI, GPU, and HPC Data Centers: The Infrastructure Behind…
Vinod Khera
Vinod Khera
GPU data center
AI data center
data center
data center cooling
digital twin
Cadence Reality Digital Twin Platform
AI, GPU, and HPC Data Centers: The Infrastructure Behind Modern AI
10 Feb 2026 • 6 minute read
Artificial intelligence (AI) is stretching compute infrastructure well beyond what traditional enterprise data centers were designed to handle. Modern AI training requires massively parallel compute, low-latency networking, high-throughput storage pipelines, and facility engineering that can safely support higher rack power densities than legacy environments. These demands are fueling the emergence of AI data centers, purpose-built environments where compute, networking, storage, power delivery, cooling, and operations are engineered as an integrated system.
In this blog, we’ll demystify what defines an AI data center, GPU data centers, high-performance computing (HPC) principles that shaped AI, and why training and inference often require different infrastructure decisions. We’ll also cover the practical constraints—power, cooling, and sustainability—and close with how Cadence Reality Digital Twin Platform helps teams validate designs before they build or retrofit.
What Defines an AI Data Center?
Most data centers look similar from the outside, but the workloads behave very differently. Traditional enterprise environments often run loosely coupled applications (databases, ERP, email). In contrast, AI/ML training and HPC workloads are frequently tightly coupled and synchronized, making them sensitive to latency, bandwidth, and tail performance. The defining features of an AI data center include:
  • Specialized hardware: GPUs are the workhorse for training; TPUs/NPUs and ASICs may be used for specific inference paths.
  • High-throughput parallel processing: Training scales across many accelerators using distributed computation.
  • Robust, low-latency fabrics: Networks must sustain heavy east–west traffic and collective communication.
  • AI-optimized storage pipelines: Multi-tier storage and parallel I/Os prevent GPU starvation.
  • High-density power + advanced cooling: AI racks increasingly exceed what air cooling handles reliably; liquid cooling is becoming a must at higher densities.
  • Security and compliance: Model IP and sensitive datasets require strong controls and auditing.
Why GPUs Dominate Modern AI Data Centers
GPUs are foundational to AI because neural networks rely heavily on matrix and tensor operations that map efficiently to GPU parallelism and mixed precision arithmetic. Modern GPUs provide thousands of arithmetic units organized into streaming multiprocessors (SMs) and include specialized tensor engines optimized for formats such as BF16/FP16/TF32/FP8.
As AI models scale, performance becomes increasingly constrained not just by compute, but by memory bandwidth (feeding compute efficiently) and communication bandwidth (moving gradients/activations efficiently). GPUs rely on HBM for bandwidth and benefit from memory hierarchy optimizations (e.g., L2/L1 caching behavior) and kernel fusion to reduce memory traffic.
Networking and Interconnects
At AI scale, the network is not “just connectivity.” It’s a core part of the compute architecture. Within a node, GPU-to-GPU links enable fast collective operations; across nodes, fabrics carry synchronized training traffic.
Ethernet + RoCEv2: Why Congestion Control Matters
High-performance Ethernet is also used, especially with RDMA over Converged Ethernet (RoCEv2). But achieving consistent training performance requires careful congestion management:
  • RoCEv2 commonly relies on Priority-based Flow Control (PFC) for lossless behavior and Explicit Congestion Notification (ECN) for signaling congestion.
  • Data Center Quantized Congestion Notification (DCQCN) is a widely referenced end-to-end congestion control approach for RoCEv2 that combines ECN marking with rate adaptation to improve throughput and fairness.
Designing GPU Clusters
GPU cluster design connects multiple GPUs into a cohesive platform that trains models efficiently and reliably.
GPU Clusters
 In production environments, several factors dominate outcomes:
  • Topology and latency consistency: If one GPU slows down due to congestion, thermal throttling, or contention, the entire job can stall behind a “straggler.”
  • Communication patterns: Data parallelism, tensor/pipeline parallelism, and mixture-of-experts (MoE) can produce very different traffic patterns, including heavy all-to-all traffic. The network must be designed and tuned for these patterns, not just headline bandwidth.
  • Host connectivity and placement: Within a server, performance depends on PCIe bandwidth, GPU/NIC topology, and NUMA-aware placement. PCIe 5.0 operates at 32GT/s and is commonly described as delivering ~64GB/s theoretical bandwidth for x16 (practical throughput is lower due to overhead). Misplacing NICs relative to GPUs or oversubscribing PCIe switches can quietly reduce effective training throughput.
  • Fault tolerance: At a large scale, failures are expected. Clusters need checkpointing, recovery workflows, redundant fabric paths, and failure-domain isolation (rack/pod segmentation) to prevent routine faults from becoming full-job restarts.
Cluster Operations: Scheduling, Observability, and Utilization
Real AI data centers are not just hardware; they are operations and control-plane engineering.
  • Scheduling and orchestration: AI training often requires co-scheduling many GPUs, fair-share policies, preemption strategies, and quota management—especially in multi-tenant environments.
  • Observability and telemetry:At scale, teams need visibility into GPU thermals/utilization, network congestion, storage latency, and job health to detect anomalies early and maintain predictable throughput.
HPC as the Foundation
HPC data centers solved many of the technical challenges AI now faces: low-latency interconnects, advanced scheduling, liquid cooling, and CFD-based thermal modeling. AI data centers extend these principles at larger commercial scales with faster upgrade cycles.
This is why the most successful AI data centers borrow from HPC disciplines: topology-aware networking, workload-aware scheduling, and physics-based thermal validation.
AI Training vs. Inference Infrastructure (Throughput vs Latency)
Not all AI workloads stress infrastructure equally. The training-versus-inference split should guide facility and platform design decisions early.
Training is about maximizing accelerator utilization and minimizing communication stalls. Techniques such as ZeRO and Fully Sharded Data Parallel (FSDP) improve memory efficiency but can increase communication intensity, making network stability and congestion control even more critical.
Inference must handle variable traffic, deliver stable tail latency, and fail over quickly. Efficiency techniques such as quantization, distillation, batching, and optimized attention implementations help reduce the cost per query. GPUs remain important, but purpose-built inference accelerators are increasingly used where predictable latency and power efficiency matter most.
Power Delivery for High-Density Racks
AI is pushing rack density into a territory that requires rethinking of power distribution. Industry sources commonly cite AI-capable racks in the 30kW to 100kW+ range, with 100kW+ emerging as a design target in advanced AI/HPC contexts.
Key considerations include:
  • Efficient distribution paths: Conversion losses turn into heat, increasing the cooling load.
  • Rack-level DC and busbars: OCP materials discuss Open Rack variants including 48V busbar in ORv3, noting that lower-voltage designs (e.g., 12V) drive higher current and higher I²R losses unless heavier copper is used.
  • Protection and safety: As density rises, fault currents and arc-flash risk increase, requiring careful protection engineering.
  • Resilience alignment: N+1 or 2N should match uptime and business requirements.
As rack densities increase, liquid cooling for AI data centers, including direct-to-chip liquid cooling and immersion cooling, is becoming essential. CFD-based analysis helps optimize both air and liquid cooling approaches to ensure reliable, efficient, and scalable data center cooling.
Sustainability: Beyond PUE
AI data centers consume significant energy and may increase water use depending on the cooling method. Improving sustainability includes:
  • Reducing cooling energy via liquid-based systems
  • Optimizing airflow in mixed environments
  • Leveraging free cooling where climate permits
  • Improving electrical efficiency (UPS, PDUs, and PSUs)
Sustainable AI Data center
It’s also essential to expand measurement beyond power usage effectiveness (PUE). OCP sustainability guidance emphasizes that PUE is widely used but can be challenging to compare across sites due to variability in measurement boundaries and operating conditions.
A more complete sustainability picture includes water usage effectiveness (WUE) and carbon usage effectiveness (CUE). The most sustainable design is often the one that optimizes power, water, and carbon together, not PUE in isolation.
Cadence Reality Digital Twin Platform: Validate Performance Before You Build
As rack densities rise and cooling architectures diversify, design mistakes become expensive. The Cadence Reality Digital Twin Platform helps teams simulate airflow, thermals, and failure scenarios—before procurement or construction locks in decisions.
For example, the Cadence Reality Digital Twin Platform supports the creation of physics-based virtual models (including CFD-based simulation) to explore configurations and failure conditions and improve confidence in design decisions.
See How Your Data Center Will Perform Before You Build or Modify It
Planning a new data center or scaling an existing facility for higher rack densities, liquid cooling, or changing workloads? Connect with Cadence for a data center design assessment or live product demo. Our collaborative approach helps you visualize airflow patterns, uncover thermal risk zones, assess cooling effectiveness, and understand capacity constraints—so you can make confident, data-driven decisions earlier in the design process.
Discover Cadence Data Center Solutions
  • Cadence Reality Digital Twin Platform to simulate and optimize data center behavior across both design and operational phases.
  • Cadence Celsius Studio to analyze and manage thermal performance from the rack level up to the whole facility.
Read More
  • Data Center Design and Planning
  • Data Center Cooling: Thermal Management, CFD, & Liquid Cooling for AI Workloads
  • What Is Power Usage Effectiveness (PUE) in Data Centers?
