  2. Data Center
  3. Data Center Cooling: Thermal Management, CFD, & Liquid Cooling…
Veena Parthan
Veena Parthan
data center
data center cooling
digital twin
Celsius Studio
Cadence Reality Digital Twin Platform
Data Center Cooling: Thermal Management, CFD, & Liquid Cooling for AI Workloads
3 Feb 2026 • 6 minute read
Data center cooling is now a first-order design constraint, not an afterthought, as AI, hyperscale cloud, and semiconductor workloads drive higher power densities. Effective data center thermal management combines airflow strategies, such as hot aisle/cold aisle and containment strategies, with data center thermal simulation using computational fluid dynamics (CFD) to predict performance and reduce risk early in the design process.
As rack densities increase, liquid cooling for AI data centers, including direct-to-chip liquid cooling and immersion cooling, is becoming essential. CFD-based analysis helps optimize both air and liquid cooling approaches to ensure reliable, efficient, and scalable data center cooling.
Data Center Thermal Management Basics
At its core, data center thermal management focuses on controlling temperature, airflow, and heat removal to ensure IT equipment operates within safe limits. As rack power densities now routinely exceed 30 kW and are accelerating toward 100 kW+ in modern AI and accelerator‑dense architectures, traditional assumptions about airflow and room‑level cooling are no longer sufficient.
Modern data centers must handle highly non-uniform heat loads. GPU clusters for AI training generate concentrated hotspots, while adjacent storage or networking racks may dissipate significantly less heat. This imbalance makes blanket cooling approaches inefficient and risky.
Thermal management strategies typically address three layers:
Room level:
  • Includes the placement of computer room air conditioner (CRAC) or computer room air handler (CRAH) systems
  • Focuses on airflow distribution throughout the room
Row and rack level:
  • Employs hot aisle and cold aisle layouts
  • Implements containment systems to manage airflow and temperature
Component level:
  • Utilizes liquid cooling for processors
  • Directly removes heat at the source for improved efficiency
Effective data center cooling requires visibility across all three layers. Without that system-level understanding, overcooling becomes common, energy efficiency suffers, and thermal margins shrink as workloads scale.
CFD for Data Centers: Why Thermal Simulation Matters
CFD for data centers has become a critical design and operational tool because it allows engineers to visualize airflow and temperature behavior before physical changes are made. Data center thermal simulation helps answer questions that cannot be resolved through rules of thumb alone.
CFD simulation helps identify where hotspots develop as rack density increases, quantify the impact of recirculation on inlet temperatures under partial load, and predict how airflow behavior changes when containment is introduced or modified.
Cadence supports data center thermal analysis through CFD capabilities that model airflow, heat transfer, and complex geometries. Engineers can evaluate multiple design scenarios digitally, reducing reliance on costly trial-and-error adjustments in live facilities.
For hyperscale operators and automotive semiconductor labs alike, simulation enables better planning for capacity expansion. It also supports energy optimization initiatives by identifying overcooled zones and inefficient airflow paths. As sustainability targets become stricter, data center cooling efficiency is increasingly tied to business performance.
Hot Aisle/Cold Aisle and Containment Strategies
Hot-aisle/cold-aisle layouts remain a foundational element of data center cooling. By aligning server intakes toward cold aisles and exhausts toward hot aisles, facilities can reduce mixing and improve cooling efficiency.
However, layout alone is rarely enough at higher power densities. This is where containment strategies play a critical role. Cold-aisle containment prevents cold supply air from escaping into the room, while hot-aisle containment captures exhaust air and directs it back to cooling units.
CFD-based analysis is particularly valuable here. Even well-intentioned containment designs can introduce pressure imbalances or unintended leakage paths. Simulation helps validate containment effectiveness under different load conditions and failure scenarios, such as a cooling unit outage.
For semiconductor validation labs and AI development environments, where uptime and thermal stability are non-negotiable, validated containment strategies help maintain consistent inlet temperatures across densely packed racks.
Direct-to-Chip and Immersion Cooling
As air cooling approaches its practical limits, liquid-based approaches are gaining traction. Direct-to-chip liquid cooling uses cold plates attached to CPUs, GPUs, and accelerators to remove heat more efficiently than air.
This approach significantly reduces thermal resistance and allows higher power densities without excessive airflow. It is particularly relevant for AI training clusters, where processors operate at sustained high utilization.
Immersion cooling takes this concept further by submerging entire servers in dielectric fluid. Heat is transferred directly to the fluid and removed via heat exchangers. While immersion cooling offers compelling thermal performance, it introduces design, maintenance, and operational considerations that must be evaluated carefully.
Data center thermal simulation remains essential even in liquid-cooled environments. Fluid flow, heat exchanger placement, and interactions between liquid and remaining air-cooled components still influence overall system performance. Cadence simulation tools help teams assess these interactions holistically rather than in isolation.
Liquid Cooling for AI Data Centers
Liquid cooling for AI data centers has transitioned from being an experimental option to becoming a critical necessity. With GPU power levels continuing to escalate and rack densities surpassing the capabilities of traditional air-cooling systems, liquid cooling provides a reliable and efficient solution. This technology ensures optimal thermal management, enabling data centers to handle high-performance computing (HPC) workloads while maintaining energy efficiency and system stability.
AI workloads differ from traditional enterprise computing in both intensity and duration. Training large language models (LLMs) or running autonomous driving simulations can push hardware to sustain thermal limits for days or weeks at a time.
Direct-to-chip liquid cooling is often the first step, enabling higher rack densities while maintaining familiar server architectures. Some hyperscale operators are also piloting hybrid approaches, combining liquid-cooled processors with air-cooled memory and networking components.
From a design perspective, these hybrid environments demand accurate modeling. Data center thermal simulation helps teams understand how liquid and air-cooling systems interact, where residual hotspots may form, and how redundancy strategies perform under fault conditions.
For automotive and semiconductor AI use cases, where validation cycles are tightly scheduled, avoiding thermal surprises is critical. Simulation-driven design reduces deployment risk and accelerates production time.
Designing the Future of Data Center Cooling with Cadence
Before adopting liquid cooling, data center designers and operators must understand how liquid cooling will affect overall data center performance. The Cadence Reality Digital Twin Platform, simulates airflow and temperature behavior to inform critical design decisions. These CFD-driven digital twins provide a structured way to evaluate how a data center will respond to new and complex technologies, including liquid cooling.
Modeling liquid cooling with full 3D representations can be computationally intensive. Cadence data center software overcomes this challenge by linking detailed 3D models with flow network representations, enabling faster solve times and more comprehensive thermal analysis.
See How Your Data Center Will Perform Before You Build or Modify It
Planning a new data center or scaling an existing facility for higher rack densities, liquid cooling, or changing workloads? Connect with Cadence for a data center design assessment or live product demo. Our collaborative approach helps you visualize airflow patterns, uncover thermal risk zones, assess cooling effectiveness, and understand capacity constraints—so you can make confident, data-driven decisions earlier in the design process.
Discover Cadence Data Center Solutions
  • Cadence Reality Digital Twin Platform to simulate and optimize data center behavior across both design and operational phases.
  • Cadence Celsius Studio to analyze and manage thermal performance from the rack level up to the full facility.
Read More
  • Data Center Design and Planning
  • What Is Power Usage Effectiveness (PUE) in Data Centers?
  • AI, GPU, and HPC Data Centers: The Infrastructure Behind Modern AI
  • Choosing the Right Data Center Strategy: Colocation vs Hyperscale vs Enterprise
