  3. Library Characterization Tidbits: Basics of Standard Cell…
AbhaRawat
AbhaRawat
tidbits
SPICE netlist
Standard Cell
characterization
Liberty Files
Spectre
Digital Implementation
Characterization Solution
Liberate
Inside-View
Liberate Characterization Portfolio
Rapid Adoption Kits
ECSM
RAKs
CCS
Model Files
Library Characterization Tidbits: Basics of Standard Cell Characterization and More
20 Nov 2019 • 2 minute read
Hey, it’s Thursday! Time to keep the promise of bringing to your Inbox some quick bit about an existing or newly introduced library characterization feature, news, or related update through this Library Characterization Tidbits blog series.
So, let’s get started, and focus on how you can use the Cadence® LiberateTM Characterization solution for characterizing standard cell libraries.
Library Characterization Quick Tip
The Liberate characterization solution is an ultra-fast standard cell, I/O, and complex multi-bit-cell library characterization solution that generates electrical cellviews for timing, power, and signal integrity, including advanced current source models (CCS and ECSM).
Characterization of standard cell libraries is broadly divided into the following five stages:
Standard Cell Characterization Flow
  1. Define settings and templates of the required cells and models, and the related Process, Voltage, Temperature (PVT) conditions for the characterization session.
  2. Read SPICE netlist into Liberate to process the standard cells and models for Inside-View functional recognition and vector generation.
  3. Run pre-processing checks on the standard cell information from the SPICE netlist to automatically identify paths where pins and related pins statically interact.
  4. Run characterization using a full SPICE solver like Spectre® APS. Characterization covers all the arcs for all slews and loads.
  5. Generate the model files. In this stage, after the completion of the characterization run for all the arcs, the results are merged and a final Liberty (.lib) file is written out.
To assist you in understanding the process from tool installation and configuration to all five stages mentioned above, we have a Rapid Adoption Kit (RAK) available on the Cadence Support portal. This RAK provides a walk through of the Tcl command interface of Liberate characterization and instructs the new users step-by-step to characterize standard cell libraries.
Rapid Adoption Kit
To download the RAK and the related tutorial, click Using Liberate to Characterize Standard Cells. You can also search for this RAK on the page displayed from the Resources – Rapid Adoption Kits menu of the Cadence Support portal.
For more information about working with the Liberate Characterization solution, see the following references:
  • Liberate Characterization Reference Manual
  • Liberate Characterization Portfolio Command and Parameter Support Matrix
About Library Characterization Tidbits
Library Characterization Tidbits is a blog series aimed at providing insight into the useful software and documentation enhancements in the LIBERATE release. In addition, this series would broadcast the voice of different bloggers and experts, who would share their knowledge and experience about all the  tools in Liberate Characterization Portfolio. To receive notifications about new blogs in this series, click Subscribe and submit your email ID in the Subscriptions box.
Happy Reading!
Abha Rawat
