  3. Can AI + EDA Really Fix IR Drop? Inside the Voltus InsightAI…
sakshin
sakshin
Training and Support
Innovus Implementation System
badge
Power Integrity
Voltus InsightAI
Digital Implementation
IR drop
Can AI + EDA Really Fix IR Drop? Inside the Voltus InsightAI Training Course
5 Apr 2026 • 3 minute read
For decades, Electronic Design Automation (EDA) has been driven by deterministic algorithms, expert-crafted heuristics, and ever-growing compute power. But as chips scale and technologies shrink, traditional EDA approaches are hitting a complexity wall.
Enter Artificial Intelligence. AI helps designers navigate complexity, uncover hidden patterns, and accelerate signoff with confidence.
The  “Voltus InsightAI 25.1” is designed to help design engineers understand why traditional IR fixing struggles and how AI‑assisted, in‑design IR mitigation can dramatically shorten closure cycles while preserving PPA.
Why EDA Needs AI Now More Than Ever
Modern SoCs are fundamentally different from their predecessors:
  • Designs exceed 2 billion instances
  • Power grids span multiple voltage domains
  • 3D‑IC and chiplet-based architectures introduce system-level effects
  • Advanced nodes (7nm → 2nm) with tight signoff margins
  • Strong coupling between power, timing, signal integrity, and thermal effects
Why Power Integrity Is AI’s First Target
Power integrity sits at the intersection of massive data, complex interactions, and late-stage risk—exactly the kind of problem AI is best suited to tackle.
Power integrity (PI) is:
  • Highly multi-dimensional (space, time, voltage, activity, temperature)
  • Non-linear (small changes can trigger large failures)
  • Context-dependent (the same IR hotspot can have different root causes)
  • Late-stage painful (fixes often impact timing, area, and routing)
EDA tools already generate enormous volumes of data—IR drop maps, activity annotations, timing windows, parasitics, EM rules, package models. The bottleneck is no longer analysis but it is interpretation.
What Is Voltus InsightAI?
Voltus InsightAI is Cadence’s AI‑driven, in‑design power integrity solution that uses a generative AI model to predict, analyze, and fix IR drop issues early and incrementally within the Innovus digital implementation flow.
Key characteristics introduced in the course include:
  • A fast IR inferencing engine that enables rapid, incremental IR analysis
  • IR drop diagnostics that identify true root causes using aggressor–victim relationships
  • Multi‑method fixing that is timing‑ and DRC‑aware
  • Seamless integration with Innovus for pre‑route and post‑route fixing
The course emphasizes that Voltus InsightAI is an in‑design IR prevention and repair mechanism that dramatically improves productivity and predictability.
Training Content
The course walks through the full Voltus InsightAI flow, including:
  • Pre‑route RPG (Reinforce Power Grid)
  • IR‑Aware Placement (IRAP)
  • Post‑route RPG, PG metal fill, and IR‑ECO
  • Automated and timing‑aware fixing
Benefits of Voltus InsightAI
According to the training material, Voltus InsightAI delivers:
  • Early IR analysis during implementation
  • Greater than 2X productivity improvement
  • Significant reduction in IR violations
  • Faster IR closure with better PPA outcomes
  • Tight integration with Cadence digital tools
Learning and Training
Want to dive deep into the topic? Enroll in our free online training course.
  • Voltus InsightAI Training Course | Cadence
There is also a Digital Badge available for the training.
Related Courses
  • Voltus Power Grid Analysis and Signoff with Stylus Common UI Training Course | Cadence
  • Innovus Block Implementation with Stylus Common UI Training Course | Cadence
Want to share this and other great Cadence learning opportunities with someone else?
Tell them to subscribe.
Hungry for training? Choose the Cadence Training Menu that’s right for you.
Explore our Accelerated Learning option for faster skill-building
References
Training Bytes Understanding Effective Instance Voltage (EIV)
  Meet Voltus InsightAI: The Cadence's AI-Powered IR Drop Solution (Video)
  Voltus InsightAI Innovations: Redefining IR Drop Metric Evaluation using TIV (Video)
  Powering Up Voltus InsightAI: A Guide to Inputs and Licensing (Video)
  Automated Power Grid Reinforcement with Voltus InsightAI: add_reinforce_pg Explained (Video)
  Hotspot Prediction and Debugging with get_ir_diagnostics (Video)
Blogs Voltus Voice: Breaking Ground with Voltus InsightAI—Swift Implementation via RAK - Digital Design - Cadence Blogs - Cadence Community
  Voltus Voice: Breaking Ground with Voltus-InsightAI—A Detailed Exploration - Digital Design - Cadence Blogs - Cadence Community
  Voltus Voice: Breaking Ground with Voltus InsightAI—AI’s Debut in EM-IR Analysis - Digital Design - Cadence Blogs - Cadence Community
YouTube Videos Voltus Insight AI: Cadence’s Generative AI Solution for IR Drop Fixes
  Industry’s First Generative AI Technology to Automatically Identify and Address EM-IR Violations
  Voltus Power Signoff Solution (IR Drop, EM Analysis & Full-System Reliability)
  IR Drop in VLSI (How It Impacts Timing, Clock Skew & Design Performance)
Please see the course learning maps for a visual representation of courses and course relationships. Regional course catalogs may be viewed here.
*If you don’t have an ASK account, go to Cadence User Registration and complete the requested information.
