  3. Every Step a Story: What Trekking Taught Me About Short…
P Saisrinivas
P Saisrinivas
High-Level Synthesis
EDI
Low Power
Genus
RTL2GDSII Flow
YouTube Shorts
Cadence Online Support
encounter
training bytes
digital implementation
Digital Implementation
Innovus
implementation
Synthesis
online training
Every Step a Story: What Trekking Taught Me About Short Steps!
11 Mar 2026 • 4 minute read
I recently went on a trek to the largest monolithic hill in Asia, and it was my first ever trek in my life.
When I started the trek, I was filled with excitement and confidence. The fresh air, beautiful mountains, and natural sounds energized me. I felt prepared both mentally and physically. Like many, I expected the journey to be challenging but manageable. However, seeing the large hill from below frightened me, but I chose to stay positive and moved slowly, carefully taking each step.
There was a moment when I was unable to move forward due to the steep slope. I felt like giving up, but in the end, I discovered a stronger version of myself by taking tiny steps forward. The best part of trekking isn’t just the summit photo, but the journey—the small wins, surprises, climbs, and quiet moments of realization.
After finishing the trip successfully, I returned with sore legs, a full gallery, and one surprising takeaway:
 "In trekking, careful steps aren’t enough; even tiny steps matter for success."
Why can't we apply the same technique while learning the critical concepts? Can we learn any critical concepts in short videos? Yes, we have something similar to help you with YouTube Shorts, as mentioned below. These will help you learn the concepts quickly in seconds/minutes.
In this 1-minute concept video, you will learn about the timing relationship between the data path and clock path in relation to setup slack, along with the mathematical expression for setup slack used in Static Timing Analysis (STA).
In this 1-minute concept video, we will demonstrate what hold slack is and the mathematical expression of hold slack, including defining the data and clock paths between register-to-register.
In this 1-minute concept video, we explain what clock skew is, why it occurs, and the different types—positive skew, negative skew, and zero skew, and their impact on setup and hold timing.
In this 1-minute video, we explain the timing derate and the significance of late and early timing derates used in static timing analysis with OCV, and how STA tools utilize them to reflect real-world process and voltage variations.
In this 1-minute video, we will describe Common Path Pessimism Removal (CPPR) in Static Timing Analysis: an overview of its purpose, how it affects slack by illustrating a timing path between reg to reg.
In this 1-minute video, we will explain clock uncertainty in static timing analysis, including the factors used to calculate it, such as clock jitter, clock skew, and additional margin. We will also demonstrate clock uncertainty constraints in an SDC file with an example.
To learn more about shorts, you can find many such YouTube Shorts/Videos under Customer Education – Shorts on various topics. With this YouTube Shorts, learning becomes effortless and accessible. Whether you’re traveling by bus, train, or cab—or just waiting in line—you can learn in a few seconds. No logins, no setup, no barriers. Just open YouTube, watch a Short, and gain knowledge instantly.
"Cadence brings learning into everyday moments—quick, simple, and on the go." You can subscribe to this channel for more information and daily videos/shorts updates: Cadence Design Systems YouTube Channel
Want to Learn More?
The Cadence RTL-to-GDSII Flow training is available as both "Blended" and "Live" and free Online Training training. Please reach out to Cadence Training for further information — Watch this video.
  • Get ready for the most thrilling experience with Accelerated Learning!
And don't forget to obtain your Digital Badge after completing the training!
If you would like to stay up-to-date with the latest news and information about Cadence trainings and webinars, subscribe to the Cadence Training emails.
Related Blogs
Mini Clips, Mini Videos, Mega Crave: Why Short Reels Dominate Screens
AI’m Always With You While Working
RTL-to-GDSII Backend Webinar: Couldn’t Make It? We Saved You a Front Row Seat
Training Insights – Why Is RTL Translated into a Gate-Level Netlist?
Did You Miss the RTL-to-GDSII Webinar? No Worries, the Recording Is Available!
Clock Tree Synthesis (CTS): The Backbone of Physical Design
