  3. Four-For-One: Four AI Super Agents, One Chip Design Journey…
P Saisrinivas
P Saisrinivas
Digital Design and Signoff
ChipStack
RTL2GDSII Flow
Virtuoso Studio
Innovus Implementation System
AI Assistant
simvision
AuraStack
AI ChatBot
analog
Xcelium Logic Simulator
InnoStack
design verification
Digital Implementation
chip design automation
Layout design
RTL design
physical implementation
ViraStack
Four-For-One: Four AI Super Agents, One Chip Design Journey!
23 Nov 2026 • 5 minute read
Fix timing, and power creeps up. Trim power, and congestion pops up somewhere new. Every chip designer knows this loop, and it gets harder as designs grow while senior engineering talent stays scarce. Cadence's answer is a team of AI Super Agents that pair LLM reasoning with trusted EDA tools: ChipStack for RTL design and verification, ViraStack for analog and custom design, InnoStack for digital implementation and signoff, and AuraStack for the package and board. This blog post covers what each stack does, how it connects to PPA, and which fundamentals still let you judge what the agents hand back.
How a Super Agent Works
Cadence's AI Super Agents blend LLM-based generation with principled EDA tools. A Super-Agent breaks a complex objective into tasks and delegates them to sub-agents, and those call Cadence tools directly. AgentStack, a head agent, orchestrates them all. Cadence says this gives autonomous AI coverage across the chip design flow.
Two ideas sit underneath. A mental model gathers design data, specifications, and intent into a single source of truth for the agents. Original skills teach the LLMs how to drive Cadence tools and read their logs.
Meet the Four Super Stacks
ChipStack: The Front-End Co-Designer
ChipStack coordinates parallel agents for RTL generation, testbench creation, regression orchestration, and debug. They share a mental model of design intent, hierarchy, and specifications, which keeps the output spec aligned.
  • Early evaluations: The RTL Generation Agent delivered on average 24% less area and 18% less power than pure foundation-model code generation, with 100% functionally accurate RTL.
ViraStack: The Analog Co-Pilot
Analog design carries heavy manual effort and iteration. Paired with Virtuoso AI Studio, ViraStack automates design migration, verification, post-layout optimization, and layout generation. You guide it in natural language, and it can reuse proven IP from your libraries and prior designs.
  • Designers of every experience level get guided automation, which helps teams ramp faster and apply best practices more consistently.
InnoStack: The Closure Engine
InnoStack covers synthesis and place-and-route through signoff analysis and ECO implementation. Its agents tune constraints, floorplans and timing, power, and area goals, and run parallel experiments at scale. They uncover fixes that manual teams can't practically attempt.
  • RTL optimization: Tunes RTL and synthesis constraints with Genus and Innovus+
  • Floorplan: Evaluates options to reduce congestion and improve routability
  • Multi-Die Planning: Extends the flow to chiplets with the Integrity 3D-IC Platform
AuraStack: The System Integrator
A great die still has to live on a package and a board. AuraStack coordinates agents across system planning, implementation, constraints management, design reuse, manufacturability, and multiphysics analysis for PCBs, packages, and 3D-IC. It is accelerated on the Cadence Millennium M2000 Supercomputer. Because it is designed to catch system issues earlier, it aims to reduce the risk of costly respins.
The Big Picture
Super Agent
Domain
Think of it as…
Key takeaway
ChipStack
Digital RTL design and verification
The front-end co-designer
Spec to RTL, testbenches, regressions, and debug
ViraStack
Custom and analog IC
The analog co-pilot
IP reuse, migration, optimization, and layout
InnoStack
Digital implementation and signoff
The closure engine
Parallel exploration from synthesis to signoff
AuraStack
PCB, package, and 3D-IC
The system integrator
Multiphysics-aware planning through signoff
Beginners: Start with natural-language prompts, then study the results to learn the flow. Advanced engineers: hand off repetitive setup, exploration, and debug, and keep the architecture and tradeoff decisions.
Where AI Meets PPA and TAT
PPA runs through the implementation-focused stacks, especially ChipStack's RTL Generation Agent and InnoStack. An agent can explore floorplans, constraints, and settings at scale, but you still decide what is worth keeping. Faster timing is no win if it breaks the power budget.
Take power. Dynamic power follows P = αCV²f, so it falls with lower switching activity, voltage, or frequency. Clock gating, DVFS, and multi-supply voltage (MSV) are the usual levers. Leakage power is a different problem. It falls with multi-Vt cell selection, body biasing, and power shutoff. Knowing which lever attacks which component helps you judge whether an agent's result is real progress.
Build the Fundamentals: Innovus Low-Power Stylus Course
Innovus Low-Power Flow with Stylus Common UI v26.1: An eight-hour course, available as v26.1, in which you explore and implement low-power techniques that reduce both dynamic and leakage power. After the course, you will be able to:
  • Implement multi-supply multi-voltage (MSMV) regions to reduce power
  • Implement a low-power clock tree
  • Run concurrent timing, MSV, and multi-Vt (leakage) optimization
  • Implement MSMV-aware detail routing
  • Analyze data and debug power problems at different stages of the flow
You should have experience with design methodology, Innovus, and the fundamentals of the IEEE 1801 Low-Power Specification Format. Cadence lists Innovus Block Implementation with Stylus Common UI as a related course.
The course has a Digital Badge option. Check the Cadence course page and the Cadence Learning system for the current version, exam availability, and earning criteria. These fundamentals help you judge what the agents produce.
Course page: Innovus Low-Power Flow with Stylus Common UI (Course 86259)
Continue Learning: From Quick Insights to Deeper Expertise
Need a quick refresher? Complement the course with Cadence Customer Education Training Bytes and short videos covering practical topics around low-power design, power planning, power analysis, and Innovus implementation. Training Bytes are available across ASK and YouTube, including both long-form and short-form video content.
Some particularly relevant topics to consider are:
Implementing Low-Power Using Innovus Technology
Low Power Optimization Using Always-on Buffers
Understanding the Types of Cells Used in Low-Power Designs
How to Run Power Analysis and Analyze the Results in Innovus Implementation System
What is Power Planning
Creating Power Rings, Power Stripes, and Power Rails in the Innovus Implementation System
Learn at Your Own Pace with Accelerated Learning
Already familiar with some of the fundamentals? Cadence Accelerated Learning helps personalize the online training experience. Start with a pre-quiz to assess your existing knowledge, then focus your learning on the areas where you need it most. If you prefer to review everything, the full learning path remains available
References
  • ChipStack AI Super Agent
  • ViraStack AI Super Agent
  • InnoStack AI Super Agent
  • AuraStack AI Super Agent
  • Reimagining Chip Design: From Spec to Signoff with Cadence AI Super Agents (Cadence Blogs)
  • Smarter, Longer, Cooler: Low-Power Flow for the Devices That Never Sleep (Cadence Blogs)
