  3. Knowledge Booster Training Bytes - In-Design Pegasus Signoff…
JentilTom
JentilTom
Pegasus Verification System
pegasus
DRC
training bytes
Innovus
signoff
silicon signoff
RAKs
verification
Knowledge Booster Training Bytes - In-Design Pegasus Signoff Verify Design (SVD)
12 Dec 2022 • 5 minute read
Are you still struggling with time-taking and iterative SignOff Verification cycles?
In-design Pegasus Signoff Verify Design (SVD) might be your answer!
What Is In-Design Pegasus Signoff Verify Design (SVD)?
In the advanced node designs, as the physical dimension of devices and interconnect are shrinking, the design rules are growing in count and complexity. Since design verification and testing take a major chunk of the time spent in the product development process, any saving here is a grace.
In the traditional signoff checking, violations such as Design Rule Checking (DRC), Layout Versus Schematic (LVS), and Electrical Rule Checking (ERC) are accumulated over the Innovus implementation stages. Signoff checks, which run late in the design cycle, tend to prop up surprises and lead to multiple iterations of debugging, fixing, and validation cycles.
In-design Pegasus Signoff Verify Design (SVD) integrates Pegasus Signoff and Pegasus SmartVerify with Innovus. These checks help you maintain your designs' DRC and LVS clean through the design cycle and help you achieve zero DRC and zero shorts out of Innovus, thus saving overall development time.
Pegasus SVD integrates Pegasus Signoff and Pegasus SmartVerify with Innovus.
Signoff Verify Design Features
  • Reads Innovus database and merges with the IP - No overhead time.
  • Runs SVD checks in the background.
  • Runs incremental or interactive DRC.
  • Runs simultaneously without interrupting Innovus.
  • Performs customized SVD checks.
  • Integrates Pegasus Results Viewer and Pegasus Design Review for easy DRC fix.
Signoff Verify Design Suite
Pegasus Signoff Verify Design suite consists of:
  1. Signoff DRC: Configurable signoff checking at every design stage.
  2. SmartVerify LVS: Fast (~10x) short and open checking and debugging. Uses the signoff LVS deck.
  3. SmartVerify DRC: Early dirty design handling.
Pegasus SVD suite consists of Sign-off DRC, SmartVerify LVS, and SmartVerify DRC.
Innovus Integrated Signoff Closure with Pegasus Verification
Pegasus SVD is integrated with Innovus and helps in performing various checks at each step resulting in cleaner DRC and shorts. This flow provides the flexibility of using either inbuilt switches or configure custom switches to run subsets of rule checks at different stages.
SVD Videos
We have created the Signoff Verify Design channel that consists of five videos to help you learn the concept in detail.
  • InDesign Pegasus Signoff Verify Design (SVD) Overview (Video)
  • How to Set up and Run Pegasus SignOff Verify Design (SVD) DRC? (Video)
  • How to Cross-probe Signoff Verify Design (SVD) Results Using Pegasus Design Review (Video)
  • Signoff Verify Design (SVD) with HMF Database and Switches (Video)
  • How to Debug Shorts and Opens with InDesign Pegasus SmartVerify LVS (SVLVS)? (Video)
To view these videos and other collaterals, you should have access to the Cadence Support Portal. If you do not have access, then follow the steps below to create your account:
  • On the Cadence Learning and Support portal, select Register Now and provide the requested information on the Registration page.
If you have questions about courses, schedules, online, public, or live onsite training, reach out to us at Cadence Training.
Want to Learn More?
Register for Pegasus Verification System v22.1 (Online) course. This course has been designed for user-level physical design verification.
Become Cadence Certified
Cadence Training Services now offers digital badges for this training course. These badges indicate proficiency in a certain technology or skill and give you a way to validate your expertise to managers and potential employers. You can highlight your expertise by adding these digital badges to your email signature or any social media platform, such as Facebook or LinkedIn. To become Cadence Certified, you can find additional information here. Go straight to the course exam at the Learning and Support Portal.
 Video
Running Pegasus DRC within Innovus Implementation System
 Rapid Adoption Kit
 InDesign Pegasus Signoff Verify Design – Interactive Signoff DRC checking from within Innovus (SVD)
 InDesign Pegasus SmartVerify LVS – Fast & interactive shorts / opens / erc checking from within Innovus (SVLVS)
Knowledge Booster Training Bytes is an online journal that relays information about Cadence Training videos, online courses, and upcoming webinars that are available in the Learning section of the Cadence Learning and Support portal. This blog category brings you direct links to these videos, courses, and other related material, on a regular basis.
Subscribe to receive email notifications about our latest Custom IC Design blog posts.
Jentil K Tom
