  3. You Know "How," But Do You Remember "Why"?
VNelson
VNelson
training
training bytes
Digital Implementation
Innovus
physical implementation
1 Jun 2026 • 2 minute read
Let's be honest.
As engineers—especially in VLSI physical design—we are exceptionally good at figuring out how to do things.
Need to place macros? Done.
Route critical nets? No problem.
Insert fillers, EndCaps, DCaps? We've got scripts, flows, and muscle memory for all of it.
But here's the uncomfortable question: Do we still remember why we're doing any of this?
Somewhere between tapeout deadlines, congestion maps, and timing waiver justifications, the why quietly disappears… and suddenly we're debugging problems we unknowingly created ourselves.
That's exactly why we created a series of quick, one-to-two-minute YouTube Shorts—to revisit the "why" behind everyday P&R decisions. Not theory. Not textbooks. Just fast, practical reminders that save hours of pain later.
Let's take a quick tour.
Macro Placement: Because Timing Is Routing Dependent
We all know how to place macros. Snap to grid, legalize, optimize, move on.
But when the why is forgotten? You get:
  • Long detoured routes
  • Congestion hotspots
  • Pins facing the wrong direction
Suddenly, timing closure feels like negotiating with a stubborn router.
Watch: Fix Macro Fails
Macro placement defines the communication flow of your design. Ignore that, and your router will make… creative decisions.
Wire Shielding: Because Signals Have SI Issues
Yes, you know how to apply shielding.
But if you forget why, you either:
  • Shield everything (hello congestion), or
  • Shield nothing (good luck explaining the side effects)
Watch: Wire Shielding Explained Simply
Shielding is about protecting critical nets that must behave. Think clocks, resets—not your average nets.
DCap Cells: Because Voltages Are Not Ideal
You know the flow: Insert DCaps, check IR drop, move on.
But forget why, and suddenly:
  • Dynamic IR drop bites your timing
  • Voltage glitches show up uninvited
  • Debug sessions get… character-building
Watch: All About DCap
DCaps aren't filler—they're local batteries for your design. Without them, voltage drops exactly when your circuits need stability the most.
EndCap Cells: Because Boundaries Matter
EndCaps often get treated like checkbox items in the flow.
Until they're missing. Then you discover:
  • Boundary DRC violations
  • Broken well continuity
  • Signoff failures that weren't supposed to exist
Watch: EndCaps Matter
EndCaps enforce structural confidence at the edges. Ignore them, and your layout will fail signoff.
Filler Cells: Because Gaps Are Not Your Friends
Filler cells—the unsung heroes that no one remembers until it's too late.
Skip them, and suddenly:
  • Well continuity breaks
  • Implant violations appear
  • Late-stage DRC fixing becomes your weekend plan
Watch: Don't Skip Fillers
Those tiny gaps between cells? They're not harmless and need to be filled in.
Why YouTube Shorts?
Because sometimes, you don't need a two-hour lecture. You need a 60-second reminder that saves you six hours of debugging.
These Shorts are built exactly for that:
  • Fast refreshers
  • Practical "why" explanations
  • Easy to revisit before (or after Smile) things go wrong
Final Thoughts
Engineering isn't just about doing things faster. It's about doing the right things for the right reasons.
So, the next time you run your flow automatically, pause for a second and ask: "Do I remember why I'm doing this?"
Find more videos on the "Cadence Education Training Bytes" YouTube channel.
If you would like to delve deeper into the topics, you can do so via a Cadence ASK account. Here you will find Training Byte videos and online training available 24/7. Most of our training courses also have an accelerated learning and digital badge option.
Related Blog Posts
  • The "EDA" Protein Bar: Compact Nutritious Learning for Billion Transistor World
  • Every Step a Story: What Trekking Taught Me About Short Steps!
