  2. Marine
  3. self propulsion using actuator disk
  • State Verified Answer
  • Subscribers 6
  • Views 4023
saji vf
saji vf over 2 years ago
we are trying to do self propulsion analysis using actuator disk but we don't have any open water data to include , actually in demo case 8 of numeca the case file has done with actuator disk only but they used open water data for running the case.
can you explain how to run the self propulsion with AD.
Thank you.
  • Benoit Mallol
    Benoit Mallol over 2 years ago +1 verified
    Hi, I suggest that you spend time reading the chapter: "Fine Marine > User Guide > Actuator Disk > Global Parameters", since it explains all the approaches. Actually, open water data are optional, it…
  • Benoit Mallol
    +1 Benoit Mallol over 2 years ago
    I suggest that you spend time reading the chapter: "FineTm Marine > User Guide > Actuator Disk > Global Parameters", since it explains all the approaches.
    Actually, open water data are optional, it is always better if available but not necessary. Hence, the Body force update should be done based on the ship's drag (called "Body drag" in the GUI) and the rest will follow. The number of required parameters is less important than open water data.
    Best regards,
    Benoit
  • saji vf
    0 saji vf over 2 years ago in reply to Benoit Mallol
    Thank you for the info, then after keeping body drag to it should we on self propulsion dynamic library for actuator disk for self propulsion analysis.
  • Benoit Mallol
    0 Benoit Mallol over 2 years ago in reply to saji vf
    Hi, I am not sure I understand your last post. Was it a question?
    The dynamic library is not required unless you want to impose the Thrust Horsepower (THP) and compute the ship advancing speed. We have described the information in: FineTm Marine > User Guide > Self-propulsion > Introduction. you can follow the recommendations and the self-propulsion library will be launched automatically for the simulation.
    Best regards
