  2. Marine
  3. planning hull
  • State Verified Answer
  • Subscribers 6
  • Views 5487
planning hull
saji vf
saji vf over 2 years ago
we are using savitsky method while doing a planing regime case for a single speed with different configurations.
now my question is:
1.I have made meshes for different configurations and ran for single speed, can i reuse the mesh for different speeds or i need to do new mesh for every single speed.
Thank you.
  • Benoit Mallol
    Benoit Mallol over 2 years ago +1 verified
    Hi, you can use the same mesh for different speeds, if the speeds are not too different. This is all because the mesh deformation might handle so large motions. However, if you activated the Overset…
  • Benoit Mallol
    +1 Benoit Mallol over 2 years ago
    you can use the same mesh for different speeds, if the speeds are not too different. This is all because the mesh deformation might handle so large motions. However, if you  activated the Overset option, you can handle any speed but simulation cost will be twice higher approximately.
    Best regards,
    Benoit
  • saji vf
    0 saji vf over 2 years ago in reply to Benoit Mallol
    i ran the case for 2.57m/s, can i use the mesh for 2.67,3.08m/s .
    thank you.
  • Benoit Mallol
    0 Benoit Mallol over 2 years ago in reply to saji vf
    most probably yes, difference is not that huge.
