  2. Online CFD Course
  3. Converegence Monitor & Work units
  • State Verified Answer
  • Answers 1
  • Subscribers 9
  • Views 6427
LukasOde
LukasOde over 3 years ago
Hello together,
is there a way to refresh the convergence monitor? Sometimes it get stucked and none of changes are displayed. For example I can’t zoom/move the curves, change the axis or selected Simulations.
The second question is about the work units. Is it correct that they have decimal places? I ticked the box foor latest value and get values like .8624. In my understanding it’s similar to the iterations.
Best regards,
Lukas
  • Manuel NIB
    Manuel NIB over 3 years ago in reply to LukasOde +1 verified
    Hi Lukas, okay then you could try the following: Go to GUI Styles in the bottom menu. Duplicate your preffered GUI style. Rename it, if you want. Activate and select the new created GUI sytel…
  • Manuel NIB
    0 Manuel NIB over 3 years ago
    Hi Lukas,
    let me answer your questions.
    Refresh convergence monitor
    In a future version is already a refresh button integrated. What you can do in the current version to refresh is rather indirect: Select the convergence monitor, deselect and select the simulation you are monitoring.
    But actually you description rather sounds like a "broken convergence monitor". Is this a behaviour you can reproduce?
    Work units
    Yes it is correct that the work units can have decimals. I have explained that in the demonstration. 1 iteration without multi-grid algorithm is equal to 1 work unit. 1 iteration with multi-grid algroithm is >1 work unit. During the coarse grid initialisation 1 iteration is <1 work unit. The work unit represents the computational cost.
    Does that help you?
    Best regards
    Manuel
  • LukasOde
    0 LukasOde over 3 years ago in reply to Manuel NIB
    Hi Manuel,
    thanks for your answer. Yeah, refreshing isn’t a problem. While the simulation is running it updates itself, depending on what I have set.
    Maybe you’re right with the "broken convergence monitor" but for the moment I can’t tell you exactly what it triggers. But it happens more than 5 times while I completed the first three challenges.
  • Manuel NIB
    +1 Manuel NIB over 3 years ago in reply to LukasOde
    Hi Lukas,
    • Go to GUI Styles in the bottom menu.
    • Duplicate your preffered GUI style. Rename it, if you want.
    • Activate and select the new created GUI sytel.
    • Actiavte the option advanced widgets in the section GUI behaviour. Now you see the 2 small arrows in the top right corner of each view.
    • Use the arrow icon to delete the convergence monitor:
    • You now have the choice what should be displayed in this view. Select simulation monitor.
    Does it work now again?
    Best regards
    Manuel
  • LukasOde
    Okay, thanks. I will try it if I have the same trouble in challenge 4.
