  2. Online CFD Course
  3. M_Mesh Setup 1 Error: some process did not pass initial...
  • State Verified Answer
  • Replies 10
  • Subscribers 9
  • Views 13889
M_Mesh Setup 1 Error: some process did not pass initialization
Larsne
Larsne over 3 years ago
Hallo, in Module 4 bekomme ich den oben genannten Fehlercode.
Tipps wie das verändern des Seed Points, komplett von neu anfangen oder den Haken bei parallel in den controll settings wegmachen helfen leider auch nicht. Habe mich komplett an die Einstellungen der Fallbeschreibung gehalten.
Hat jemand Tipps? Vielen Dank schonmal.
  • Larsne
    Larsne over 3 years ago in reply to Colinda +2
    Thank you all for your help :) I created a new file and saved it in the same path where all the other challenges are saved. Now it works!
  • Manuel NIB
    Manuel NIB over 3 years ago in reply to Larsne +1 verified
    Hi Lars, I checked your vlog and I the following lines: NIStorage::findLocalName(FileSystem 1, c:\challenge 5 ) starts NIStorage::findLocalName() fs is not network file system and path c:\challenge…
  • Larsne
    Larsne over 3 years ago in reply to Manuel NIB +1
    C:\Users\lnehr\Desktop
  • Manuel NIB
    +1 Manuel NIB over 3 years ago in reply to Larsne
    Hi Lars,
    NIStorage::findLocalName() fs is not network file system and path c:\challenge 5 does exist
    NIProjectManager::answerCloseRequest starts from Client_lnehr_5.2-a913
    NIProjectManager::answerCloseRequest() calls session()->delayedQuit()
    It seems that for some reason the file path "c:\challenge 5" cannot be accessed by the mesh generation process.
    1. Did you save the other projects also right away under c:\ ?
    2. Did you make any changes or maybe updates with you anti virus software since the last challenge?
    3. Could you try to restart your computer (not shut down and start - the Windows restart option) and launch the mesh generation once again?
    4. If point 3 does not help:
      1. Use the save project input option, to save your project under a new file path & name (e.g. under C:\users\[your Windows user name]\Documents\challenge_3
      2. Close the project.
      3. Open the just saved project (this will ensure only the saved data is opened
      4. Launch the mesh generation again.
    Please let me know, once you have tested the points above.
    Best regards
    Manuel
  • Colinda
    0 Colinda over 3 years ago in reply to Manuel NIB
    Hi Manuel and Lars,
    It would indeed be good to use a new path without blank spaces.
    Best regards,
    Colinda
  • Larsne
    0 Larsne over 3 years ago in reply to Colinda
    • Vote Up +2 Vote Down
  • Manuel NIB
    0 Manuel NIB over 3 years ago in reply to Larsne
    Hi Lars,
    just for our understanding: Could you share the full path with us please?
    Best regards
    Manuel
  • Larsne
    0 Larsne over 3 years ago in reply to Manuel NIB
