  2. Online CFD Course
  3. M_Mesh Setup 1 Error: some process did not pass initial...
  • State Verified Answer
  • Replies 10
  • Subscribers 9
  • Views 14129
M_Mesh Setup 1 Error: some process did not pass initialization
Larsne
Larsne over 3 years ago
Hallo, in Module 4 bekomme ich den oben genannten Fehlercode.
Tipps wie das verändern des Seed Points, komplett von neu anfangen oder den Haken bei parallel in den controll settings wegmachen helfen leider auch nicht. Habe mich komplett an die Einstellungen der Fallbeschreibung gehalten.
Hat jemand Tipps? Vielen Dank schonmal.
  • Larsne
    Larsne over 3 years ago in reply to Colinda +2
    Thank you all for your help :) I created a new file and saved it in the same path where all the other challenges are saved. Now it works!
  • Manuel NIB
    Manuel NIB over 3 years ago in reply to Larsne +1 verified
    Hi Lars, I checked your vlog and I the following lines: NIStorage::findLocalName(FileSystem 1, c:\challenge 5 ) starts NIStorage::findLocalName() fs is not network file system and path c:\challenge…
  • Larsne
    Larsne over 3 years ago in reply to Manuel NIB +1
    C:\Users\lnehr\Desktop
  • Manuel NIB
    0 Manuel NIB over 3 years ago
    Hi Lars,
    please see my German answer below. If okay for you, please could you answer in English please, as our conversation would be less confusing for other students, who can take advantage of your topic.
    Unfortunantely it is not obvious to say what went wrong. The seed point was my assumption in another post. Could you do please the following to things:
    1. Deactivate the parallel option in the control tab, save the project and run the mesh generation again.
    2. Open the command manager from the bottom control panel. Find the mesh generation process either in the section of the running or the finished processes. Select it. Check the output of the selected process. Use the button to copy it and paste it here.
    Leider gibt es keine klare Standardantwort. The Seed Point war eine Vermutung von mir. Versuche bitte Folgendes:
    1. Deaktiviere die parellel Option im Control Tab, speichere das Projekte und starte die Vernetzung erneut.
    2. Öffne den Command Manager aus dem unteren Control Panel. Finde den Vernetzungsprozess entweder in dem Bereich der laufenden Prozesse oder der abgeschlossenen Prozess. Wähle den Vernetzungsprozess aus. Nun siehst du den Output des Prozesses. Kopiere den Output über den Button und füge ihn hier im Forum ein.
    Best regards
    Manuel
  • Larsne
    0 Larsne over 3 years ago in reply to Manuel NIB
    Wenn ich den Vernetzungsprozess auswähle, ist der Output leer.
  • Manuel NIB
    0 Manuel NIB over 3 years ago in reply to Larsne
    Hi Lars,
    okay that will become a bit more tricky then. Please do the following:
    • Navigate to your project folder and open folder Document_1
    • Inside you should find one or more file names like Computation_UId_100000000066559-Name-Mesh Setup 1
    • Indentify the correct file name, which you tried to launch in the Omnis GUI
    • You will find a related folder like Computation_UId_100000000066559
    • Open that folder and open then inside the folder defaultRun
    • Inside the folder defaultRun you should find:
      • A file with extension .log
      • A file with extension .vlog
    • Please open both files with an editor like notepad and paste the content here in the forum.
    Best regards
    Manuel
  • Larsne
    Inhalt der vlog Datei:
    NIThreadPoolsManager::createAllPools() starts
    NIThreadPoolsManager::createAllPools() ends
    NIThreadPoolsManager::initAllThreadPools(10, 5,5) starts
    NIThreadPoolsManager::initAllThreadPools() ends
    NISession::init(argc, argv) starts
    NISession::setUpSignalHandlers() starts
    NISession::setUpSignalHandlers() ends
    NIPropertiesDatabases::init() starts
    NIPropertiesDatabases::readUnitsSystem() starts
    read Unit System: S.I. units
    NIPropertiesDatabases::readUnitsSystem() ends
    NIPropertiesDatabases::init() ends
    NISession::updateStatistics() starts
    NISession::updateStatistics() ends
    Initialization of hybrid config files starts
    Initialization of hybrid config files ends, mc_base::filesPath_C:\Program Files (x86)\NUMECA Software\OMNIS 5.2\_resources\hexpressfiles\
    NIMemoryManager() constructor ends
    NIVectorTime:: constructor ends
    NIMemoryManager::initSocketRingBuffer() starts
    NIMemoryManager::initSocketRingBuffer() ends
    NICommandManager constructor ends
    [NIPythonSession::NIPythonSession] Constructor starts
    [NIPythonSession::NIPythonSession] Constructor ends
    NIParasolidSession constructor ends
    NIResourceManager constructor ends
    end NIValidationDatabaseManager::userInitialization()
    NIValidationDatabaseManager::init() starts
    NIValidationDatabaseManager::init() ends
    NIProjectManager::userInitialization() ends
    Initialize Parasolid...
    NIParasolidSession::start() start
    NIParasolidSession::start - Parasolid session precision = 1e-08
    NIParasolidSession::start() ends
    Initialize Datakit ...
    NIResourceManagerForServer::init() starts
    Start NIComputerNetwork::init()
    -> found 1 LANs to add
    -> found 0 computers in LAN Numeca Int.
    -> found 4 clusters to add
    No filesystem equivalence found in NIComputerNetwork::init()
    MISSING LOCAL HOST in RESOURCES
    End NIComputerNetwork::init()
    Start NIResourceManager::startLocalDaemon()
    NIRemoteDaemonClient::startDaemonIfNotRunning(...)
    start NIRemoteDaemonClient::isRunningDaemon(LarsLapTop, 40000, ...10000)
    connected to NIRemoteDaemonServer
    Daemon is running
    ~NIRemoteDaemonClient() starts p:0000025E9F33A4E0
    NISocketThread::socketCloseAndWaitDelete LarsLapTop:40000 p:0000025E9F9801E0
    NISocketConnection::preDeleteSocket() starts
    NISocketConnection::preDeleteSocket() needs delete p: 0000025E9F556150
    disconnected slot, socket: 0000025E9F556150
    NISocketConnection::preDeleteSocket() ends
    socketCloseAndWaitDelet ends state 0 p:0000025E9F9801E0
    NISocketClient::closeAndWaitDelete() state 0 or 1, p:0000025E9F33B0B0
    NISocketClient::threadFinished() starts
    NISocketClient::threadFinished() p:0000025E9F33B0B0
    NISocketClient::threadFinished() before signaling father ?0000000000000000
    NISocketClient::threadFinished() destroy father
    NISocketClient::threadFinished() ends
    NISocketClient::disconnectSignals
    NISocketClient destructor starts 1 p:0000025E9F33B0B0
    NISocketClient::closeAndWaitDelete no thread p:0000025E9F33B0B0
    NISocketClient destructor ends1 p:0000025E9F33B0B0
    ~NIRemoteDaemonClient() ends p: 0000025E9F33A4E0
    ok, found running daemon
    Start NIResourceManager::startLocalDaemon() => success
    NIResourceManager::getSessionMaster()
    trying masterComputer LarsLapTop masterPort 64016
    =>found master Client_lnehr_5.2-a913 on LarsLapTop
    NIProjectManager::init with client
    This process Id is Server_lnehr_5.2-a914
    WARNING daemon on LarsLapTop has incomplete processInfo
    NIResourceManager::updateOmnisSessions() adding session {e1215e6a-3a7c-4e7a-a2a6-665b8e94b718}
    NIFusionServer registering client Client_lnehr_5.2-a913
    call to NIResourceManagerForServer::clientProcessConnectedToServer during session start
    Client registered
    NIResourceManager::publishFusionClient starts, p: 0000025E1572B240
    NIResourceManager::publishFusionClient registerNode p:0000025E1572B240
    call to NIResourceManagerForServer::registerNode starts
    NIResourceManager::niFusionClientRegistration starts Client_lnehr_5.2-a913
    NIResourceManager::niFusionClientRegistration found isInitializing
    call to NIResourceManagerForServer::registerNode ends
    NIResourceManager::publishFusionClient ends, p: 0000025E1572B240
    NIResourceManager::updateOmnisSessions() adding session {00000000-0000-0000-0000-000000000000}
    sendInitFeedBacks() #targets 1
    NIResourceManagerForServer::init() ends
    Initialize GUI...
    NIPageElementDatabase constructor starts
    NIPageElementDatabase constructor ends
    Restore session starts
    Restore session ends
    NIFusion::start_phase Memory: 0 Megabytes
    call to NIResourceManagerForServer::dedicateComputationServer, timeout 10000
    NIResourceManager::addProcessGroups
    updating process group with{e1215e6a-3a7c-4e7a-a2a6-665b8e94b718}
    Process Server_lnehr_5.2-a914 on LarsLapTop uses port 64309
    NIStorage::findLocalName() fs is not network file system and path c:\challenge 5 does exist
    NIProjectManager::answerCloseRequest starts from Client_lnehr_5.2-a913
    NIProjectManager::answerCloseRequest() calls session()->delayedQuit()
    NISession::delayedQuit in main thread
    setting LastFiFoMessageId Project Manager request to close all managed sessions from Client_lnehr_5.2-a913 OLId 4 to 27
  • Larsne
    0 Larsne over 3 years ago in reply to Larsne
    log Datei
