  2. Turbo
  3. change the working directory path
  • State Verified Answer
  • Subscribers 6
  • Views 6143
sriluta
sriluta over 3 years ago
Hey together,
in the moment iam using the local  hard disk of my computer. I would like to change permanently the working directory path  to an external hard disk. How can I do that ? Iam using windows 10 and Omnis 5.2,
thx Hussein
  • Colinda
    Colinda over 3 years ago in reply to sriluta +1 verified
    Hi Hussein, The OpenLabs module in Omnis 5.2 is included in the free student license provided that the system requirements for the use of OpenLabs are met of course. I'm not so sure having the .numeca…
  • Colinda
    OpenLabs is part of Omnis. You can find the information how to access it in the Omnis 5.2 documentation under: OMNIS tools > Simulation > Optional models > OpenLabs > How to use OpenLabs Make sure…
  • domen
    0 domen over 3 years ago
    what do you mean by working directory? Is it the .numeca folder or another set of preference?
    thanks
  • sriluta
    0 sriluta over 3 years ago in reply to domen
    Hi domen, yes the .numeca folder. I would like to use  a External hard drive memory. Numeca is installed on the local hard disk of my computer. By the way another question, do I have with the student license access to OpenLabs ? In the moment iam just using Omnis 5.2
  • Colinda
    +1 Colinda over 3 years ago in reply to sriluta
    Hi Hussein,
    I'm not so sure having the .numeca folder on an external hard drive is a good idea to do as the speed of access is less than on a local disk. I would not recommend it. Saving your project files on an external hard drive on the other hand, is something I think should be ok. It may just take longer for reading and writing to disk.
    Best regards,
    Colinda
  • sriluta
    0 sriluta over 3 years ago in reply to Colinda
    How can I install the OpenLabs module. The email I received, or in the download area I see only omnis and fine marine.
    Yes I actually like your idea better too. T
    his means that I have to run the simulation on the local storage, is there a possibility that the simulation is saved directly on the external hard disk than on the local storage? Oh no that doesn't make sense
  • Colinda
    Make sure to have a compiler installed (Microsoft Visual Studio on Windows or GNU C and C++ compiler (g++) on Linux).
    Then just select a domain in the tree and right-click to select "Edit labs".
