  2. Turbo
  3. CFView: Vortice detention and visualization
  • State Verified Answer
  • Subscribers 7
  • Views 5126
Delfim Sa
Delfim Sa over 2 years ago
I am trying to get a 3D rendering of a vortice on a rotors blade by using the quantity Lambda2.
I was able to do it by manually creating 33 IJK surfaces, in this case it was I surfaces to obtain this result:
Now without the surfaces:
Is there a quicker and easier way to obtain this result? I wanted the full domain but that were a minimum of 97 surfaces if i used J surfaces.
Do I need to just create a Macro? This is a process that I am going to need to repeat a lot and wanted to find the best way.
Thank you very much for any help.
Delfim Sá
  • Colinda
    Colinda over 2 years ago +1
    Dear Delfim Sá, I noticed your question and I'm wondering whether you could not use an iso-surface at Lambda2 = 0 (or a very small negative value) to visualize in 3D the vortices? Best regards, Coli…
  • Colinda
    Colinda over 2 years ago in reply to Delfim Sa +1 verified
    You are using CFView, right? The isosurfaces are created in all domains: when you save them, you can see in the list of surfaces a new surface that is expandable and contains the surfaces within each of…
  • Gaurav
    0 Gaurav over 2 years ago
    For optimal results, it is advisable to create a script file when dealing with several surfaces. To enhance comprehension of the script file, it is recommended to visit support.cadence.com and read the CFView user guide, specifically chapter 8, which covers the "Macro Language.".
  • Colinda
    0 Colinda over 2 years ago
    Dear Delfim Sá,
    Best regards,
    Colinda
  • Delfim Sa
    0 Delfim Sa over 2 years ago in reply to Colinda
    Dear Colinda,
    Thank you very much for your suggestion. It works very well. Can I select the volume for which I want the ISO surface, or does it apply to all domain?
    Delfim
  • Colinda
    +1 Colinda over 2 years ago in reply to Delfim Sa
    The isosurfaces are created in all domains: when you save them, you can see in the list of surfaces a new surface that is expandable and contains the surfaces within each of the domains. In that way you can easily control which ones to look at.
