  2. Functional Verification
  3. Capacitor model SystemVerilog
  • Replies 8
  • Subscribers 70
  • Views 27064
NE555
NE555 over 10 years ago
Hi to everyone,
I'm working on systemverilog code for my mixed signal IC, to improve the velocity of the simulation. For the resistor and capacitor connected to ground i use the model from cadence, but now i need the model for a capacitor without a pin connected to ground.
to made it i fuse the code of resistor (with P and N terminal) and the code of capacitor connected to ground. the code work and the behavior of component is ok, but not the tension and current value. the code is this:
`timescale 1ns/1ps
import EE_pkg::*;
module  Cap(
inout EEnet P,
inout EEnet N,
input real cval
parameter real vtol=1e-6;    // voltage tolerance for iterations.
parameter real rmin=1e-4;    // minimum differential resistance.
parameter real rmax=1e2;    // "off" resistance for Z
parameter real itermax=20;   // max iterations at one timepoint.
parameter real rs=1;        // voltage tolerance for iterations.
real Rval;                        // limited versions of rs inputs
real VPin,RPin,VNin,RNin;              // inputs with small changes ignored
real VPeff,RPeff,VNeff,RNeff;          // effective external V & R values
real VPdrv,RPdrv,VNdrv,RNdrv;          // voltage & resistance output drives
real TPdrv=0,TNdrv=0;                  // time of most recent driver updates
integer iterP=0,iterN=0;               // number iterations at this timepoint
parameter real ic=0;       // initial capacitor voltage at time zero
parameter real tinc=1e-10;  // timestep for computing voltage update (sec)
parameter real itol=1e-7;  // minimum current
real Vcap=ic,Tcap=0,Icap=0; // voltage on capacitor @ time, and current value
real Inew;                  // recomputed current at end of interval
real tinct = tinc*1s;       // tinc converted to timescale units
real Vout,Tout;             // voltage value to output pin (limited update)
reg ck=0;
always #(tinct) ck=!ck;   // toggle clock at defined rate
real Vcapn=ic,Tcapn=0,Icapn=0; // voltage on capacitor @ time, and current value
real Inewn;                  // recomputed current at end of interval
initial begin   // block starts in "off" mode, effective values are as measured:
  VPdrv=0;
  RPdrv=rmax;
  VNdrv=0;
  RNdrv=rmax;
  VPeff=P.V;
  RPeff=P.R;
  VNeff=N.V;
  RNeff=N.R;
end
// update VPin,RPin,VNin,RNin but skip LSB type changes:
always @(P.V,P.R) begin
  if ((abs(P.V-VPin)<1e-14)==1'b0)       VPin=P.V;
  if ((abs(P.R-RPin)<=RPin*1e-14)==1'b0) RPin=P.R;
end
always @(N.V,N.R) begin
  if ((abs(N.V-VNin)<1e-14)==1'b0)       VNin=N.V;
  if ((abs(N.R-RNin)<=RNin*1e-14)==1'b0) RNin=N.R;
end
// update Rval whenever rs change, filtering special cases:
always begin
  if (rs<rmin)       Rval=rmin;      // min resistance
  else if (rs>rmax)  Rval=rmax;      // max resistance
  else                 Rval=rs;      // normal resistance
  @(rs);
end
always begin
  if ($realtime>TPdrv) begin        // new timepoint
    TPdrv=$realtime;                // save time value
    iterP=0;                        // start counter
  end
  else begin
    iterP+=1;                       // else increment counter
    if (iterP==itermax) $display(
     "<EE> ERROR: instance %M node P unconverged at T=%.0fns", $realtime);
  end
  if (iterP<=itermax) begin
          RPeff = RPin*RPdrv/(RPdrv-RPin);
 RNeff = RNin*RNdrv/(RNdrv-RNin);
  Inew = (rs==0)? P.I : (P.V-VPeff)/rs;   // compute new current
  Vcap += (Inew+Icap)/2*($realtime-Tcap)/(cval*1s);  // update voltage by I*dT
  Tcap = $realtime;                      // save time of cap computation
  Icap = Inew;
  if (abs(VPeff-Vcap)>vtol) begin  // if enough dV&dT
    VPeff <= Vcap;                        //  update output voltage
    VNeff <= P.V - Vcap;
  end
        end
    @(P.V, P.R, N.V, N.R, cval, ck);
end
assign P = '{VPeff,0,RPdrv};                        // drive output pins
assign N = '{VNeff,0,RNdrv};
endmodule
someone can help me to find the problem?
tanks
  • NE555
    i made a new code that work. there is only1 problem... if I send a square waveform, on the rising edge the model work, on the falling edge doesn't work a voltage on the N pin. this is the code: `timescale 1ns/1ps
    import EE_pkg::*;
    module Cap(
    inout EEnet P,
    inout EEnet N,
    input real cval
    parameter real rval=1; // voltage tolerance for iterations.
    parameter real vtol=1e-7; // voltage tolerance for iterations.
    parameter real rmax=1e10; // "off" resistance for Z
    real v1, v2;
    parameter real tinc=1e-11; // timestep for computing voltage update (sec)
    reg ck=0;
    real VNeff1; // voltage on capacitor @ time, and current value
    as measured:
    VPdrv=0;
    RPdrv=rmax;
    VNdrv=0;
    RNdrv=rmax;
    VPeff=P.V;
    RPeff=P.R;
    VNeff1=N.V;
    VNeff1 = ((VNin*RNdrv-RNin*VNdrv)/(RNdrv-RNin));
    VNeff = VNeff1 -Vcap;
    end
    else begin
    VNeff1 = VNin; // previously ways highZ
    RNeff = RNin;
    end
    end
    else begin // external open
    VNeff = VNin;
    RNeff = `Z;
    end
    if ((abs(VNeff-VPdrv)<vtol)==1'b0) VPdrv <= VNeff;
    RPdrv <= (RNeff+Rval<rmax)? RNeff+Rval : `Z;
    end
    else begin // no internal drive
    VNeff = VNin;
    RNeff = RNin;
    VPdrv <= VNin;
    RPdrv <= `Z; // R>1e12 uses Z
    end
    end
    @(VNin,RNin,Rval, Vcap);
    end
    always begin
    Inew = (rs==0)? P.I : ((-VNeff-VPeff)-Vcap)/rs; // compute new current
    Vcap += (((Inew+Icap))*($realtime-Tcap))/(cval*1s); // update
    voltage by I*dT
    Icap = Inew;
    end
    @(P.V, P.R, N.V, N.R, cval, ck, VPdrv, VNdrv);
    end
    assign P = '{VPdrv,0,RPdrv}; // drive output pins
    assign N = '{VNdrv,0,RNdrv};
    endmodule
  • tpylant
    tpylant over 10 years ago
    There is some missing code in your initial block. Can you repost the code?
    Tim
  • NE555
    Hi Tim. this is the code of my capacitor:
    `timescale 1ns/1ps
    import EE_pkg::*;
      module  Cap(
      inout EEnet P,
      inout EEnet N,
      input real cval
      parameter real rval=1;         // Equivalent Series Resistor
      real Rval;                     // limited versions of rval inputs
      parameter real ic=0;                  // initial capacitor voltageand current at time zero
      parameter real tinc=1e-11;            // timestep for computingvoltage update (sec)
      parameter real itol=1e-7;             // minimum current tollerance
      real Vcap=ic,Tcap=0,Icap=0;           // voltage on capacitor @time, and current value
      reg ck=0;
     initial begin                          // block starts in "off" mode,effective values are as measured:
       VPdrv=0;
       RPdrv=rmax;
       VNdrv=0;
       RNdrv=rmax;
       VPeff=P.V;
       RPeff=P.R;
       VNeff=N.V;
       RNeff=N.R;
     end
     end
     end
     // update Rval whenever rval change, filtering special cases:
     always begin
       if (rval<rmin)       Rval=rmin;          // min resistance
       else if (rval>rmax)  Rval=rmax;      // max resistance
       else                 Rval=rval;              // normal resistance
       @(rval);
     end
     always begin
       end
       else begin
       end
         if (Rval<rmax) begin                // if connected
           if (RPin<rmax && (RPdrv==`Z || RPin!=RPdrv)) begin  // normal case
             if (RPdrv<rmax) begin                            // compute effective vals
              RPeff = RPin*RPdrv/(RPdrv-RPin);            //compute new resistence
              VPeff = ((VPin*RPdrv-RPin*VPdrv)/(RPdrv-RPin)) + Vcap;   //compute mnew tension
             end
             else begin
               VPeff = VPin;        // was undriven
               RPeff = RPin;
             end
           end
             VPeff = VPin;
             RPeff = `Z;
           end
           if ((abs(VPeff-VNdrv)<vtol)==1'b0)  VNdrv <= VPeff;
           RNdrv <= (RPeff+Rval<rmax)? RPeff+Rval : `Z;
         end
         else begin                                                     //no drive (also used for unknown drive)
           VPeff = VPin;
           RPeff = RPin;
           VNdrv <= VPin;
           RNdrv <= `Z;
         end
       end
       @(VPin,RPin,Rval, Vcap);
     end
     always begin
       if ($realtime>TNdrv) begin                                       //new timepoint
         TNdrv=$realtime;                                               //save time value
         iterN=0;                                                       //start counter
       end
       else begin
         iterN+=1;                                                     //else increment counter
         if (iterN==itermax) $display(
          "<EE> ERROR: instance %M node N unconverged at T=%.0fns", $realtime);
       end
       if (iterN<=itermax) begin
         if (Rval<rmax) begin                                           //if connected
           if (RNin<rmax && (RNdrv==`Z || RNin!=RNdrv)) begin // normal case
             if (RNdrv<rmax) begin                                     //compute effective vals
             RNeff = RNin*RNdrv/(RNdrv-RNin);               //new value of resistence
             VNeff = ((VNin*RNdrv-RNin*VNdrv)/(RNdrv-RNin))-Vcap;  //new value of tension
             end
             else begin
               VNeff = VNin;                                           //previously ways highZ
               RNeff = RNin;
             end
           end
           else begin                                                   //external open
             VNeff = VNin;
             RNeff = `Z;
           end
         end
         else begin                                                    //no internal drive
           VNeff = VNin;
           RNeff = RNin;
           VPdrv <= VNin;
           RPdrv <= `Z;                                                 //R>1e12 uses Z
         end
       end
     end
      always begin          //Capacitance
        Inew = (Rval==0)? P.I : ((-VNeff-VPeff)-Vcap)/abs(RPdrv);       //compute new current
        Vcap += (((Inew+Icap))*($realtime-Tcap))/(cval*1s);           //update voltage by I*dT
        Tcap = $realtime;                                             //save time of cap computation
        Icap = Inew;
          @(P.V, P.R, N.V, N.R, cval, ck, VPdrv);
      end
      assign P = '{VPdrv,0 ,RPdrv};                        // drive output pins
      assign N = '{VNdrv,0 ,RNdrv};
      endmodule
    this is the code of tb:
    `timescale 1ns/1ps
    import EE_pkg::*;
    module dcdc_ana_tb ();
    EEnet V_in, v1,V_out, vgnd;
    real pvval;
    initial begin
    pvval = 3.6;
    #(300)
    pvval = 0;
    #(300)
    pvval = 3.6;
    #(300)
    pvval = 0;
    end
    assign V_in = '{pvval,0, 0};
    assign vgnd = '{0,0, 0};
    EEnet vcom;
      res              res1(.P(V_in), .N(v1), .rval(1e3));
      res              res2(.P(V_out), .N(vgnd), .rval(1e3));
      Cap              Cap1(.P(v1), .N(V_out), .cval(10e-11));
    endmodule
    the code of the resistor is the following:
    `timescale 1ns/1ps
    import EE_pkg::*;
    // Shorthand for standard real constants:
    `define Z `wrealZState
    `define X `wrealXState
    module  res(P,N,rval);
    inout EEnet P,N;
    input real rval;
    parameter real rmax=1e15;    // "off" resistance for Z
    real Rval, current;                        // limited versions of rval inputs
      VPdrv=0;
      RPdrv=rmax;
      VNdrv=0;
      RNdrv=rmax;
      VPeff=P.V;
      RPeff=P.R;
      VNeff=N.V;
      RNeff=N.R;
    end
    end
    end
    always begin
      @(rval);
    end
    always begin
      end
      else begin
      end
           /* if (RPeff<=rmin) VPeff = VPin;            // ignore equiv if tiny R
              else */          VPeff = (VPin*RPdrv-RPin*VPdrv)/(RPdrv-RPin);
            end
            else begin
              RPeff = RPin;
            end
          end
            VPeff = VPin;
            RPeff = `Z;
          end
        end
        else begin            // no drive (also used for unknown drive)
          VPeff = VPin;
          RPeff = RPin;
          VNdrv <= VPin;
          RNdrv <= `Z;
        end
      end
      @(VPin,RPin,Rval);
    end
    always begin
      if ($realtime>TNdrv) begin        // new timepoint
        TNdrv=$realtime;                // save time value
        iterN=0;                        // start counter
      end
      else begin
        iterN+=1;                       // else increment counter
      end
            if (RNdrv<rmax) begin                      // compute effective vals
          /*  if (RNeff<=rmin) VNeff = VNin;            // ignore equiv if tiny R
              else */          VNeff = (VNin*RNdrv-RNin*VNdrv)/(RNdrv-RNin);
            end
            else begin
              VNeff = VNin;                             // previously ways highZ
              RNeff = RNin;
            end
          end
            VNeff = VNin;
            RNeff = `Z;
          end
        end
          VNeff = VNin;
          RNeff = RNin;
          VPdrv <= VNin;
        end
      end
      @(VNin,RNin,Rval);
    end
    endmodule
    the model of the resistor is the model made by cadence.
    The simulation circuit is very simple: a pulse generator with period 600nS, a resistor, capacitor and another resistor. the circuit and the correct resoult are the following ( sorry if I use multisim as simulator :)..... )
    the image is on my website, the first is of the correct result:
    the result with my code in system Verilog is the following:
    on the firs part, on the rising edge all both pin signal is right. on the falling edge the signal V1 is right, the signal Vout go down only for 0.1V, there is something that block the negative peak. I try to solve this but nothing.
  • vlella
    vlella over 10 years ago
    Hi Luigi,
    I am interested in your work and model you have written. I would like to know if you were able to solve the problem on the negative edge as you described. If you did could you please share it.
  • NE555
    Unfortunately, after 1 week of work without a good result I post my problem here but no one help me, so, I stop to search a solution too....
    Why you don't try to search a solution ? :) :) :)
  • Raj Mitra
    Raj Mitra over 10 years ago
    I would like to suggest a slightly different approach using a method called State Space Solver. I have attached it
  • Raj Mitra
    Continued -
  • ronvogelsong
    ronvogelsong over 10 years ago
    That problem has nothing to do with your model at all!  The model is working fine.  It is the EE_pkg itself that is imposing the limitation.  If you'll look inside the resolution function in EE_pkg, you'll see that it has limits specified for the max high and low range for resolved output voltage.  Currently they default to VHI=5.1, VLO=-0.1.  You'll need to edit those to be wider so that negative voltages will pass through without being bounded.  These limits were included in the model so that current drive into open-circuited pins would be limited to some reasonable high and low values rather than being unbounded, but the default values are obviously overly restrictive for general purpose systems.  So if you change them to for example VHI=999, VLO=-999, you'll get the operation that you expect.
