  3. ERROR (VACOMP-1008): Cannot compile ahdlcmi module library...
  • Replies 11
  • Subscribers 132
  • Views 23031
VoTuanMinh
VoTuanMinh over 12 years ago
Hi all,
I am a new commer to Cadence, when I tried to simulate with Veriloga, I got the Error as follow:
ERROR (VACOMP-1008): Cannot compile ahdlcmi module library. Check the log file input.ahdlSimDB/1085_Minh_SAR_12bit_BST_Switch_veriloga_veriloga.va.BST_Switch.ahdlcmi/Linux/../ahdlcmi.out for details. If the compiler ran out of memory, use 'setenv CDS_CMI_COMPLEVEL 0', and try again. If the reason for the failure was a syntax error, contact your Cadence Customer Support representative with the netlist, log files, behavioral model files, and any other information that can help identify the problem.
ERROR (SFE-91): Error when elaborating the instance BST_Switch. Simulation should be terminated.
And here is the content of the "ahdlcmi.out"
ahdlcmicompile: Compiling ahdlcmi in input.ahdlSimDB/1085_Minh_SAR_12bit_BST_Switch_veriloga_veriloga.va.BST_Switch.ahdlcmi/Linux/ for Linux with optimize using gcc on Mon Jun  2 17:22:04 ICT 2014 [5.0]
ahdlcmicompile: Generating makefile
PATH:  /usr/bin/Cadence/MMSIM11-10-228/tools.lnx86/cdsgcc/gcc/4.1/install/bin:/usr/bin/Cadence/IC614-500-13/bin:/usr/bin/Cadence/IC614-500-13/tools/bin:/usr/bin/Cadence/IC614-500-13/oa_v22.04.073/bin:/usr/bin/Cadence/MMSIM11-10-228/tools/bin:/usr/bin/Cadence/IC614-500-13/share/cdsdoc/bin:/usr/bin/Cadence/IC614-500-13/share/bin:/usr/bin/Cadence/IC614-500-13/tools/spectre/bin:/usr/bin/Cadence/IC614-500-13/tools/dfII/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games
LD_LIBRARY_PATH:  /usr/bin/Cadence/MMSIM11-10-228/tools.lnx86/cdsgcc/gcc/4.1/install/lib:/usr/bin/Cadence/MMSIM11-10-228/tools/lib:/usr/bin/Cadence/MMSIM11-10-228/tools.lnx86/mdl/lib:/usr/bin/Cadence/MMSIM11-10-228/tools.lnx86/mmsim/lib:/usr/bin/Cadence/MMSIM11-10-228/tools.lnx86/inca/lib:/usr/bin/Cadence/MMSIM11-10-228/tools.lnx86/spectre/lib:/usr/bin/Cadence/MMSIM11-10-228/tools.lnx86/lib/SuSE:/usr/bin/Cadence/IC614-500-13/tools/lib:/usr/bin/Cadence/IC614-500-13/tools/lib/SuSE/SLES11:/usr/bin/Cadence/IC614-500-13/oa_v22.04.073/lib/linux_rhel40_32/opt:/usr/bin/Cadence/IC614-500-13/tools/QT/lib:/usr/bin/Cadence/IC614-500-13/tools/dfII/lib:/usr/bin/Cadence/IC614-500-13/tools/sev/lib:/usr/bin/Cadence/IC614-500-13/tools/inca/lib
Can't exec "mpstat": No such file or directory at /usr/bin/Cadence/MMSIM11-10-228/tools.lnx86/spectre/ahdlcmi/bin/getCPUnum.pl line 41.
/usr/bin/Cadence/MMSIM11-10-228/tools.lnx86/spectre/ahdlcmi/bin/gnumake -j2 -f GNUmakefile
Compiling C file BST_Switch_func.c (optimize) with -O0
/usr/bin/Cadence/MMSIM11-10-228/tools.lnx86/cdsgcc/gcc/4.4/bin/gcc  -march=i686 -m32 -ffast-math -O0 -DSYSV -DSVR4 -D_REENTRANT -fPIC   -DconfigSPECTRE -I. -I/usr/bin/Cadence/MMSIM11-10-228/tools.lnx86/spectre/ahdlcmi/include -c BST_Switch_func.c -o obj/optimize/5.0/BST_Switch_func.o || rm -f -f obj/optimize/5.0/BST_Switch_func.o
Compiling C file BST_Switch_DcFuncDerLoad.c (optimize)
/usr/bin/Cadence/MMSIM11-10-228/tools.lnx86/cdsgcc/gcc/4.4/bin/gcc  -march=i686 -m32 -ffast-math -O3 -DSYSV -DSVR4 -D_REENTRANT -fPIC   -DconfigSPECTRE -I. -I/usr/bin/Cadence/MMSIM11-10-228/tools.lnx86/spectre/ahdlcmi/include -c BST_Switch_DcFuncDerLoad.c -o obj/optimize/5.0/BST_Switch_DcFuncDerLoad.o || rm -f -f obj/optimize/5.0/BST_Switch_DcFuncDerLoad.o
/bin/sh: Illegal option -h
rm -f -rf BST_Switch_func.c
rm -f -rf BST_Switch_DcFuncDerLoad.c
Compiling C file BST_Switch_DcFuncLoad.c (optimize)
/usr/bin/Cadence/MMSIM11-10-228/tools.lnx86/cdsgcc/gcc/4.4/bin/gcc  -march=i686 -m32 -ffast-math -O3 -DSYSV -DSVR4 -D_REENTRANT -fPIC   -DconfigSPECTRE -I. -I/usr/bin/Cadence/MMSIM11-10-228/tools.lnx86/spectre/ahdlcmi/include -c BST_Switch_DcFuncLoad.c -o obj/optimize/5.0/BST_Switch_DcFuncLoad.o || rm -f -f obj/optimize/5.0/BST_Switch_DcFuncLoad.o
Compiling C file BST_Switch_TranFuncDerLoad.c (optimize)
/usr/bin/Cadence/MMSIM11-10-228/tools.lnx86/cdsgcc/gcc/4.4/bin/gcc  -march=i686 -m32 -ffast-math -O3 -DSYSV -DSVR4 -D_REENTRANT -fPIC   -DconfigSPECTRE -I. -I/usr/bin/Cadence/MMSIM11-10-228/tools.lnx86/spectre/ahdlcmi/include -c BST_Switch_TranFuncDerLoad.c -o obj/optimize/5.0/BST_Switch_TranFuncDerLoad.o || rm -f -f obj/optimize/5.0/BST_Switch_TranFuncDerLoad.o
rm -f -rf BST_Switch_DcFuncLoad.c
rm -f -rf BST_Switch_TranFuncDerLoad.c
Compiling C file BST_Switch_TranFuncLoad.c (optimize)
/usr/bin/Cadence/MMSIM11-10-228/tools.lnx86/cdsgcc/gcc/4.4/bin/gcc  -march=i686 -m32 -ffast-math -O3 -DSYSV -DSVR4 -D_REENTRANT -fPIC   -DconfigSPECTRE -I. -I/usr/bin/Cadence/MMSIM11-10-228/tools.lnx86/spectre/ahdlcmi/include -c BST_Switch_TranFuncLoad.c -o obj/optimize/5.0/BST_Switch_TranFuncLoad.o || rm -f -f obj/optimize/5.0/BST_Switch_TranFuncLoad.o
Compiling C file BST_Switch_cmi_c.c (optimize)
/usr/bin/Cadence/MMSIM11-10-228/tools.lnx86/cdsgcc/gcc/4.4/bin/gcc  -march=i686 -m32 -ffast-math -O3 -DSYSV -DSVR4 -D_REENTRANT -fPIC   -DconfigSPECTRE -I. -I/usr/bin/Cadence/MMSIM11-10-228/tools.lnx86/spectre/ahdlcmi/include -I/usr/bin/Cadence/MMSIM11-10-228/tools.lnx86/cmi/include -c BST_Switch_cmi_c.c -o obj/optimize/5.0/BST_Switch_cmi_c.o || rm -f -f obj/optimize/5.0/BST_Switch_cmi_c.o
rm -f -rf BST_Switch_TranFuncLoad.c
rm -f -rf BST_Switch_cmi_c.c
/usr/bin/Cadence/MMSIM11-10-228/tools.lnx86/cdsgcc/gcc/4.4/bin/gcc -shared -O3 -fPIC -o obj/optimize/5.0/libahdlcmi.so ./obj/optimize/5.0/BST_Switch_func.o ./obj/optimize/5.0/BST_Switch_DcFuncDerLoad.o ./obj/optimize/5.0/BST_Switch_DcFuncLoad.o ./obj/optimize/5.0/BST_Switch_TranFuncDerLoad.o ./obj/optimize/5.0/BST_Switch_TranFuncLoad.o ./obj/optimize/5.0/BST_Switch_cmi_c.o  -m32 -Wl,-rpath,/usr/lib -Wl,-rpath,/lib -s
gnumake: *** [obj/optimize/5.0/libahdlcmi.so] Error 2
I read some Solved threads in this forum and tried to solve but I couldn't. (For e.x add "-64" in UsrOptionField)
Could anyone here please help me to solve this problem?
Thank you so much in advance.
Minh
    Minh,
    See this post for where it talks about dash versus bash (which is probably where the "illegal option -h" messages are coming from). What OS distribution are you using, and what do you get if you type "ls -l /bin/sh" at the UNIX prompt?
  • VoTuanMinh
    Thanks so much for your reply, I now quite understood about the problem, maybe due to the difference between "dash" and "bash".
    Here is the result when I typed the command on terminal:  "lrwxrwxrwx 1 root root 4 2013-01-16 09:55 /bin/sh -> dash"
    My OS is Ubuntu 10.04 LTS, my Cadence is IC614-500-13 and MMSIM11-10-228.
    Thus, the next question is how can I solve this problem? :)
    Sorry, I searched but I did not find out the way to solve (indeed I did not understand much as well :( ). Please help me.
    Best Regards,
    Minh
    Minh,
    First of all, Ubuntu is not a supported OS distribution - so really you should use something that is supported (Red Hat Enterprise, SuSE Enterprise).
    Failing that, you might be able to fix this by changing the link of /bin/sh to bash. This will require root access. First of all, check that "ls -l /bin/bash" exists, then:
    cd /bin
    rm sh
    ln -s bash sh
    I'm not 100% sure that this will fix your compilation problem, but I hope so...
    I tried going the other way, but I have a newer version of MMSIM on my laptop (I could check when I'm in the office), and that doesn't seem to have a problem with the wrong shell being used. So another alternative might be to install MMSIM13.1
  • VoTuanMinh
    Thanks so much for your quickly reply. I will try and inform you the result.
    Due I can not change the OS so I will try the later methods.
    Best Regards,
    Minh
  • VoTuanMinh
    You are really genuis as usual :), thanks a lot.
  • qamar
    qamar over 7 years ago in reply to Andrew Beckett
    Hi Andrew
    I am also having the same issue. I tried the
    rm sh
    command but I got reply permission denied.
    Regards
    Qamar.
    Andrew Beckett over 7 years ago in reply to qamar
    Qamar,
    You'd have to do this as root (or using sudo) - but I would suggest you do it very carefully. If you didn't know that you needed to be root to make this change, it would be wise to defer to somebody who has sufficient IT skills?
  • qamar
    Hi Andrew
    Thanks for your reply. I will try this option if this option is possible for them. I have noticed one thing if I use elements from Analog Lib (ideal resistor) instead of Foundry Lib (rpolyh) then there is no error and it is working perfectly fine for me. I am a new user of the Ubuntu environment. Don't know how to add that Foundry Lib information into it. Thanks in advance for your time in this regard.
    Best Regards
    Qamar
    Qamar,
    I'm not really sure what you're asking about with "Don't know how to add that Foundry Lib information into it". The issue you're having is with the models - it's not to do with which symbol library you use.
  • qamar
    Hi Andrew
    Thanks for your reply and sorry for the misunderstanding. I would like to say that if I am using standard cells provided by cadence then my ocean script is working. But if I am using cells provided by our process foundry then it is giving me that error.
    * My ocean script is working for both cases if I call my ocean script from the Virtuoso CIW window. But if I call the ocean script from the terminal window then it is working only with standard cells (for process foundry cells it is giving me the error).
    Best Regards
    Qamar
