  3. ADE-L Expressions
  • Views 17750
ADE-L Expressions
netbug
netbug over 9 years ago
Dear all,
I am running an AC simulation on ADE-L. Sometimes the phase starts at 0 deg, some other times at 180 deg. I would like the expressions to resolve that, so when calculating Phase/Gain Margins the result is meaningful.
I was wondering if it would be possible to implement something like an  "if" clause, in order to have different expressions according to the starting value of the phase.
Thanks in advance.
Best regards,
Pedro
  • Frank Wiedmann
    Frank Wiedmann over 9 years ago
    You could use the ternary operator. See for example http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:ViewSolution;DocumentType=tbshtng;solutionNumber=11764448 which also includes a workaround for ADE-XL prior to IC617.
  • netbug
    I only have access to the forum :-(
    Best regards,
    Pedro
  • Frank Wiedmann
    In this case, you can find the syntax at https://en.wikipedia.org/wiki/%3F:
