  3. Verilog-A, one time execution function
  • Subscribers 131
  • Views 22671
samer1
samer1 over 8 years ago
I am developing a verilog-A model for a device. I want to write a function that is executed only one time in the simulation during the device first transition from high resistive state to a low resistive state. I looked at analog events but did not find a function that provides this functionality I want. I tried to do it using an if..else statement but it gave me convergence error.
Can someone help me with that?
    It might help if you gave more detail as to what you're trying to do - i.e. the code you tried. In general if you want something just to execute once, you could have some kind of state variable which starts off at 0, and then you set it to 1 once you've executed the code - and have the code check that the value of the variable is 0 before executing it.
    However, there's probably little point giving an example of that because the problem you are having may be related to some other detail of the model - it's not clear.
    So please show what you've tried, so folks here can give you a steer in the right direction.
  • samer1
    Thanks Andrew for you reply. Here is the code:
    // VerilogA for demo, memr_model_test, veriloga
    `include "constants.vams"
    `include "disciplines.vams"
    module memr_model_test (p, n);
    inout p; //positive pin
    inout n; //negative pin
    electrical p, n;
    // SUNY parameters
    parameter real HRS = 1.5e5; // high resistance state
    parameter real LRS = 1e4; // low resistance state
    parameter real Vtp = 0.75; // positive threshold voltage
    parameter real Vtn = -1.0; // negative threshold voltage
    parameter real tsw_p = 1e-8; // time to switch under +V bias
    parameter real tsw_n = 1e-6; // time to switch under -V bias
    parameter real form = 0;
    //poly parameters
    parameter real CLRS = 1;
    parameter real CHRS = 1;
    parameter real P_LRS = 1;
    parameter real P_HRS = 1;
    parameter real Rinit = 1e4;//1e6;
    parameter real Rpre = 1e4;//1e6;
    real delR;
    real time_last;
    real Vwr;
    real Iwr;
    real delt;
    real Rm;
    real Rm_tmp;
    real delRm;
    real HRS_nom; // nominal high res, trends down w/ time
    real LRS_nom;
    real delI;
    real I_last;
    real f;
    real tmp;
    analog begin
    @ ( initial_step or initial_step("dc") ) begin
    delt = 0;
    time_last = 0;
    delI = 0;
    I_last = 0;
    f = form;
    HRS_nom = HRS;
    LRS_nom = LRS;
    Rm = Rinit;
    delR = HRS_nom - LRS_nom;
    end
    delt = $abstime - time_last;
    time_last = $abstime;
    Vwr = V(p,n);
    delI = I(p,n)-I_last;
    I_last = I(p,n);
    @ (cross (I(p,n)-220e-6, +1))begin
    LRS_nom = LRS_nom - (1e9/1e-6)*delI*delt/tsw_p;
    if (LRS_nom < 0.5 *LRS)begin
    LRS_nom = 0.5*LRS;
    end
    HRS_nom = HRS_nom - (1e9/1e-6)*delI*delt/tsw_p;
    if (HRS_nom < 2 *LRS)begin
    HRS_nom = 2*LRS;
    end
    end
    //////////////////////////////// Executes only once
    if (Vwr > 2.3)begin
    tmp =1;
    end
    if (tmp==1)begin
    Rm_tmp = Rm - delt* CLRS* (delR/tsw_p)*( pow(((Vwr-Vtp)/Vtp), P_LRS));
    if (Rm_tmp <= LRS_nom) begin
    Rm_tmp = LRS_nom;
    f = 1;
    tmp = 0;
    end
    end
    //////////////////////////////////END
    if (f == 1)begin
    if (Vwr >= Vtp && Rm != LRS_nom) begin //Vtp
    Rm_tmp = LRS_nom;
    end
    end
    else if (Vwr < Vtn && Rm != HRS_nom) begin //Vtn
    Rm_tmp = Rm + delt* CHRS * (delR/tsw_n) *(pow(((Vwr-Vtn)/Vtn), P_HRS)) ;
    if (Rm_tmp >= HRS_nom) begin
    Rm_tmp = HRS_nom;
    end
    end
    else begin
    Rm_tmp = Rm;
    end
    end
    Rm = Rm_tmp;
    I(p,n) <+ Vwr / Rm;
    end // end analog
    endmodule
    It says it does not converge as follows:
    Transient Analysis `tran': time = (0 s -> 20 us)
    Top 9 Solution Convergence failure counts accumulated from the beginning of simulation:
    1 V0:p
    1 I7:p_n_flow
    1 T0:int_d
    1 T0:int_s
    1 net6
    Top 9 Residue Convergence failure counts accumulated from the beginning of simulation:
    1 I7:p_n_probe
    1 T0:int_d
    1 T0:int_s
    1 net6
    Trying `homotopy = gmin' for initial conditions.
    5 V0:p
    5 I7:p_n_flow
    5 T0:int_d
    5 T0:int_s
    5 net6
    5 I7:p_n_probe
    5 T0:int_s
    5 net6
    Trying `homotopy = source' for initial conditions.
    8 V0:p
    8 I7:p_n_flow
    8 T0:int_d
    8 T0:int_s
    8 net6
    8 I7:p_n_probe
    8 T0:int_d
    8 T0:int_s
    8 net6
    Trying `homotopy = dptran' for initial conditions...
    5 V0:p
    5 I7:p_n_flow
    5 T0:int_d
    5 T0:int_s
    5 net6
    5 I7:p_n_probe
    5 T0:int_d
    5 T0:int_s
    5 net6
    Trying `homotopy = ptran' for initial conditions..
    5 V0:p
    5 I7:p_n_flow
    5 T0:int_d
    5 T0:int_s
    5 net6
    5 I7:p_n_probe
    5 T0:int_s
    5 net6
    Trying `homotopy = arclength' for initial conditions.
    None of the instantiated devices support arclength homotopy. Skipping.
    5 V0:p
    5 I7:p_n_flow
    5 T0:int_d
    5 T0:int_s
    5 net6
    5 I7:p_n_probe
    5 T0:int_s
    5 net6
    Error found by spectre during IC analysis, during transient analysis `tran'.
    ERROR (SPECTRE-16080): No DC solution found (no convergence).
    The values for every node on the last Newton iteration are given below. For those nodes that did not converge, the manner in which the convergence criteria were not satisfied is also given.
    Failed test: | Value | > RelTol*Ref + AbsTol
    Top 9 Solution too large Convergence failure:
    I(V0:p) = 0 A
    update too large: | -329.989 kA | > 0 A + 1 pA
    I(I7:p_n_flow) = 0 A
    update too large: | 329.989 kA | > 0 A + 1 pA
    V(net6) = 0 V
    update too large: | 1 kV | > 0 V + 1 uV
    V(T0:int_d) = 0 V
    V(T0:int_s) = 0 V
    Top 9 Residue too large Convergence failure:
    V(I7:p_n_probe) = 0 V
    residue too large: | -329.989 kA | > 1.64995 kA + 1 pA
    V(net6) = 0 V
    residue too large: | 10.066 mA | > 50.33 uA + 1 pA
    V(T0:int_s) = 0 V
    residue too large: | 617.284 A | > 3.08642 A + 1 pA
    Please comment your code (with explanation as to what each variable is for, and what each section does) - and indent it to make it readable. Right now it's too hard to try to figure out what it's doing (and what the intent is), so I'm afraid I can't spend the time figuring that out for you - it would take a large amount of time to try to unravel what you're actually trying to do here.
    If doing that on the full code is too much effort, please provide a simpler (commented and properly indented) example that illustrates what you're trying to achieve.
  • samer1
    Thanks Andrew
    I added comments and indented.
    electrical p, n;
    // SUNY parameters
    parameter real form = 0; ///////////// This is a parameter assigned to a flag "f" later
    //poly parameters
    real delR;
    real time_last;
    real Vwr;
    real Iwr;
    real delt;
    real Rm;
    real Rm_tmp;
    real delRm;
    real LRS_nom;
    real delI;
    real I_last;
    real f;
    real tmp;
    analog begin
    delt = 0;
    time_last = 0;
    delI = 0;
    I_last = 0;
    f = form;
    HRS_nom = HRS;
    LRS_nom = LRS;
    Rm = Rinit;
    end
    Vwr = V(p,n);
    I_last = I(p,n);
    LRS_nom = 0.5*LRS;
    end
    HRS_nom = 2*LRS;
    end
    end
    ////////////////////////////until here, everything is fine
    //////////////////////////////////////////////////////////////////////////////////////// HERE is the important part"
    //////////////////////////////// this if (==0).....end Executes only once: This function is executed first as long as the flag is zero. Once the flag goes one, I want the simulation to ///////////////////switch to the other functions and remains there throughout the rest of the simulation time.
    /////////////////////// once the Vwr hits 2.3, Rm should start decreasing. Once it hits LRS_nom, f is raised to "1" and this function is terminated.
    if(f==0)
    if (Vwr > 2.3)begin
    tmp =1;
    end
    if (tmp==1)begin
    Rm_tmp = LRS_nom;
    f = 1;
    tmp = 0;
    end
    end
    end
    //////////////////////// This one works fine if I initialize form as "1". The simulation works normally
    if (f == 1)begin
    Rm_tmp = LRS_nom;
    end
    end
    Rm_tmp = HRS_nom;
    end
    end
    else begin
    Rm_tmp = Rm;
    end
    Rm = Rm_tmp;
    I(p,n) <+ Vwr / Rm;
    end // end analog
    endmodule - See more at: community.cadence.com/.../1351165
    That's barely any better. I can see that the if(f==0) line doesn't have a "begin" which looks wrong, but the code is so hard to read that I can't do more debugging.
    I suggest you format it better and contact customer support.
  • samer1
    OK. I write here a simple code describing my code structure:
    ///////////////////////////////////////////////////////////////////begin code:
    some initialization:
    .... parameter real form = 0; // I initialize it as 0 or 1
    ..... real f; // f is a flag
    analog begin
    ....some dc initialization;
    f=form;
    end // end dc initialization
    //////////////// here is the one time execution function
    if (f==0)begin
    .......... some code;
    if (function is executed successfully)begin
    f=1;
    end
    end
    //////////////// end the one time execution function
    if (f==1)begin
    .... Run this part for the rest of the simulation time;
    end
    end // end analog
    ////////////////////////// End code
    Note that I only run into DC convergence error when I start the simulation with f=0. if I start with f=1, the simulation runs normally. Do you think there is something wrong with the code structure?
    Thanks!
