  2. AWR Design Environment
  3. Magnetic Permeability and Dielectric Constant of Metals...
  • Subscribers 22
  • Views 2867
Magnetic Permeability and Dielectric Constant of Metals - The Permalloy case study
Romolo Marcelli
Romolo Marcelli over 2 years ago
Hello to everybody.
I am trying to simulate with a student of my classroom some Permalloy planar structures at microwave frequencies.
The Permalloy is a metal alloy having its own magnetic permeability and conductivity.
When I define it as a new material in the AXIEM environment, the magnetic permeability is not considered (the menu is grey in the window dedicated to metal material properties definition) and I can modify only the conductivity, while if a define it as a "dielectric" material, all is possible, but with limitations in the value I can use for conductivity (since it is understood that I would like to simulate a non-metal).
Have I to do something to activate this feature for metals or have I to pass to EMSIGHT or similar alternative environmental AWR definitions?
Thank you,   Romolo Marcelli
  • OscPn
    0 OscPn over 2 years ago
    Hi Romolo,
    To use magnetic permeability option, copy or add new EM stackup in Global definitions, then the conductor definitions value is editable, select the conductor and then go to the advanced properties, and manually edit the values as per your requirements (highlighted red boxes) as shown in the figure below.  After that while creating AXIEM EM structure select the EM stackup in Global definitions.
    Santosh
  • Romolo Marcelli
    0 Romolo Marcelli over 2 years ago
    Thank you Santosh. I actually included one more metal, "Permalloy_metal," in the AXIEM environment, but it looks like I cannot modify this characteristic of the metal. What I did this morning is to change from AXIEM to Analyst, and here I can do what I need, even if I have no explanation for that... Analyst is even faster!
  • OscPn
    0 OscPn over 2 years ago in reply to Romolo Marcelli
    Thanks Romolo for sharing,  In AXIEM to modify metal characteristics update the stackup in Global definitions.  Great to know Analyst is working for your application and Analyst has conductor editable options.
  • OscPn
    0 OscPn over 2 years ago in reply to OscPn
    AXIEM can’t support magnetic conductors.
