  2. AWR Design Environment
  3. EM Axiem
  • State Verified Answer
  • Subscribers 21
  • Views 4489
EM Axiem
MTalha
MTalha over 2 years ago
When defining a line type in .lpf with a negtaive layer with an offset, the negative layer will be like a rectangle surrounding it. (first figure)
Is there a way to define a line type that have a surrounding negative layer like co-planar? (that extends only in both sides) (second figure)
Note: I create this negative layer in .lpf file edited as a text
$LINE_TYPE_BEGIN "Top Copper"
! -> Layer offset minWidth flags
"Copper" 0 5e-05 0
"Copper-" 0.001 0 0
$LINE_TYPE_END
  • OscPn
    OscPn over 2 years ago +1 verified
    For the CPW models, the default layout cells require 3 layers in the lpf file: (Layername) (Layername)+ (Layername)- The first three layers can have any name as long as there is a "neutral", "-" and…
  • OscPn
    +1 OscPn over 2 years ago
    (Layername)
    (Layername)+
    (Layername)-
    The first three layers can have any name as long as there is a "neutral", "-" and "+" layer. For example:
    First Metal = center conductor
    First Metal+ = ground
    First Metal- = space
    To Know more check the AWR example: File > Open Example... > CPW_Layout.emp
    Do you have any specific application with the CPW?
    Give this a try and let me know how it goes.
  • MTalha
    0 MTalha over 2 years ago in reply to OscPn
    yes, i am designing a PCB board. I need to make EM simulation with ground flood. I have added another question here
    community.cadence.com/.../ground-flood-in-layout
