  2. AWR Design Environment
  3. AWR doesn't seem to like noise parameters in standard s2p...
  • State Verified Answer
  • Subscribers 21
  • Views 4477
AWR doesn't seem to like noise parameters in standard s2p files
AB202408227656
AB202408227656 over 2 years ago
I'm new to cadence AWR and have been trying to reproduce older designs I did by hand to familiarise myself with it.  I tried one using a CEL3512K2 and the subcircuit block didn't seem to like the CEL S2P file.  I can't figure out why - looks standard to me, but it claims to have no ports or gives me an error about the file format but the header looks correct
! CEL
! CE3512K2
! N-channel HJ-FET
! Vds = 2 V Id = 10 mA
# Hz S MA R 50
! f S11 S21 S12 S22
! Hz MAG ANG MAG ANG MAG ANG MAG ANG
2000000000 0.97177219 -24.328886 5.5871382 151.12015 0.026992124 73.653381 0.57072973 -17.365152
I found a program, SdataConversion on the AWR site which claims to fix the file and I ran in my simulations but was suprised by the 0.1dB NF of the amplifier which turns out to be because SdataConversion stripped out all the noise data from the s2p file (was expecting around a 0.6dB NF) and reported "Negative character used as delimeter in file - fixed".  S11 and S21 simulated look similar to my Smith chart calculations.
It would be really helpful if AWR told me what it didn't like about the original file but is there a way to figure out the problem so I can try the noise simulations?
Alan
  • CurtisAWR
    CurtisAWR over 2 years ago +1 verified
    Hi Alan, Can you make a copy of the.txt file (with the noise data) provided by CEL, and change the extension to .s2p? Then go to Project > Add Data File > Import Data File, and see if that works for…
  • CurtisAWR
    0 CurtisAWR over 2 years ago
    Hi Alan,
    I was able to perform the following set of steps and (I believe) import the S-Data (with noise) successfully.
    1. I looked up that part number and found a link to the S-Parameters toward the bottom of this page: https://www.cel.com/components/low_noise_devices/.  The zip file had .txt files for each of the bias points at which the part had been measured.
    2. I extracted the file I wanted to test (CE3512K2v02n_2-26G_2V_10mA.txt) and made a copy of that file, changing the .txt extension to .s2p.
    3. In AWRDE, I imported the netlist (Project > Add Data File> Import Data File) and browsed to select that .s2p file.
    I was able to simulate and see the NF you describe (0.6 dB).  Note that while the S-Data is 2-26 GHz, the NF data in the file is given for 8-14 GHz; outside of that range, the extrapolation will make the noise simulation data suspect.
  • CurtisAWR
    +1 CurtisAWR over 2 years ago
    Hi Alan,
    Can you make a copy of the.txt file (with the noise data) provided by CEL, and change the extension to .s2p?  Then go to Project > Add Data File > Import Data File, and see if that works for you.  It works OK on my end, and I get the NF data you describe.
  • AB202408227656
    0 AB202408227656 over 2 years ago in reply to CurtisAWR
    That almost worked, file loaded but showed with no ports, but using scripts -> data-> import and selecting 2 ports and it worked!  Not quite sure what was different, but clearly it didn't like .txt ending.
