  2. AWR Design Environment
  3. Does AWR have a tool that automatically converts lumped...
  • Subscribers 22
  • Views 5363
Does AWR have a tool that automatically converts lumped element inductor to transmission line?
GT202503231457
GT202503231457 over 1 year ago
I have created a lumped element diplexer using the filter wizard on AWR. ADS has a transformation tool where you can select to convert inductors to high impedance transmission lines automatically. Does AWR have this tool? When I make a lumped element diplexer there is no option for an EM layout, and no option to create a microstrip line diplexer.
Any help would be much appreciated, thanks!
  • OscPn
    0 OscPn over 1 year ago
    Hi GT202503231457,
    Yes, you can do that.  You can transfer the design automatically from wizard itself by following these steps:
    1. Click the Analyze Real tab in the Wizard.
    2. Click Generate Design in the Wizard.
    To know more and check the images check the following article from ASK portal:
    Article (20506810) Title: How to generate layout using AWR iFilter Filter Synthesis Wizard
    URL: https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O3w000009lAc5EAE
  • GT202503231457
    0 GT202503231457 over 1 year ago in reply to OscPn
    Ok thanks - however I mean specifically to convert a lumped element filter, such as the lumped element LP/HP diplexer, where there are no physical dimensions or options to generate an equivalent EM layout - is there a tool for this case as the above does not apply?
  • OscPn
    0 OscPn over 1 year ago in reply to GT202503231457
    The process i suggested earlier with Wizard, can generate layout with all physical dimension.
    If in case you have separate circuit elements and want to convert a element only then compare the element S parameter and Transmission line layout in Smith chart (use Tuner).
  • GT202503231457
    Ok thanks - here are some photos of what I am trying to convert. So for this lumped element, I would have to do element by element?
    https://drive.google.com/file/d/17b7j7REa3eYKA-BqV7eOzBr9ciRk
    https://drive.google.com/file/d/1JfAiSP2nh6Knni8xU134On4guUZQbPlC/view?usp=sharing-N2A/view?usp=sharing
  • OscPn
    I can't download the images.  It's better to file a support ticket on https://support.cadence.com/ with the project/ image attached, and an available Application Engineer will follow up on the case.
