  3. VCAR(ICcrafstman) unconnects
  • Views 1598
stu
stu over 18 years ago
Hi there,
Does anyone know where i can get a detailed report on unsuccessful/incomplete routes in VCAR i.e why did it not complete? I can see that some of the unrouted nets would be easily done by hand. Does VCAR get its connectivity from the layout/schematic/somewhere else?
Stu
    archive over 18 years ago
    Hi Stu,
    Welcome to the community! I'm the community manager so don't have the expertise to answer you question -- someone else will be along I'm sure to do that -- but wanted to encourage you to go into your profile and choose a screen name. You can also upload an avatar if you wish. :)
  • craigth
    craigth over 17 years ago
    Stu,
    I apoligize for the much delayed response and hope that you were able to get your questioned answered through another method such as CDN Customer Support or your local AE.
     For the benefit of the forum and other users I'll provide a response.
    In response to your first question, "Does anyone know where i can get a detailed report on unsuccessful/incomplete routes in VCAR i.e why did it not complete?" Yes, their are several reports that you can generate to get information in VCAR. For your specific request you can try the following report:
    • report > uconnects
      • Lists all unconnected fromtos by net name. It includes the reference designator, pin name, and coordinate location for each pin in the fromto. The default report filename is unconn.rpt.
      • http://sourcelink.cadence.com/docs/files/Release_Info/Docs/iccraft/iccraft6.1.3/cmd_gs/report_command.htm
      • http://sourcelink.cadence.com/docs/files/Release_Info/Docs/iccraft/iccraft6.1.3/cmd_gs/report_type_descriptor.htm
    Other reports that you can use:
    •  Report > Route Status
      • http://sourcelink.cadence.com/docs/files/Release_Info/Docs/iccraft/iccraft6.1.3/report/report_route_status.htm
      • http://sourcelink.cadence.com/docs/files/Release_Info/Docs/iccraft/iccraft6.1.3/info/routing_status_report_info.htm
    Report > Net
    • http://sourcelink.cadence.com/docs/files/Release_Info/Docs/iccraft/iccraft6.1.3/report/report_net.htm
    • http://sourcelink.cadence.com/docs/files/Release_Info/Docs/iccraft/iccraft6.1.3/info/net_report_info.htm
    Report Network
    • http://sourcelink.cadence.com/docs/files/Release_Info/Docs/iccraft/iccraft6.1.3/report/report_network.htm
    In response to your observation related to your first question, "I can see that some of the unrouted nets would be easily done by hand." there are several ways to analyse and investigate why a connection is not made. First, if the connection failed automatically try to route it interactively. If it succeeds it may indicate an autorouter setup problem or bug. If it cannot route interactively or automatically it may indicate that the connection point is blocked or a rule is set prohibiting the connection. Make sure to also use the 'check' and 'report' features to show conflicts which may indicate the cause of the incomplete net.
    In response to your second question, "Does VCAR get its connectivity from the layout / schematic / somewhere else?" it really depends on your design flow and tools. VCAR can get it's connectivity from a variety of sources including the connectivity associated with the design in VXL from the layout and schematic in CDB and OA formats, DEF, translation from proprietary applications that generate the correctly formatted netlist section in the design file.
    I suggest referencing the Virtuoso Chip Assembly Router Guide if using a Virtuoso flow.
    For IC5141 CDB reference: http://sourcelink.cadence.com/docs/files/Release_Info/Docs/iccausr/iccausr5.2.51/iccausrTOC.html
     For IC61x OA reference: http://sourcelink.cadence.com/docs/files/Release_Info/Docs/iccausr/iccausr6.1.3/iccausrTOC.html
     I hope this answers your questions. If not, feel free to add to the post. I also recommend contacting Customer Support and your local AE to assist you in your use of VCAR.
