  3. how to create link between new MMSIM and ADEGXL in IC61...
  • Views 16958
how to create link between new MMSIM and ADEGXL in IC610
ashraf
ashraf over 18 years ago
hi
I am having trouble in linking MMSIM and ADEGXL.
When I try to run simulation in ADEGXL then it shows me the error “ ADEXL-1613: Following tests use older version of Spectre: sensor: inverter_new:1. Make sure to use MMSIM60 or above for these tests”.
So I installed newer version of MMSIM, MMSIM62 and MMSIM70.But the problem still exists. If anybody knows how to link between MMSIM and ADEGXL then please let me know.
Thanks for your time
regards
ashraf
  • Vignesh
    Vignesh over 17 years ago
    I have a similar problem. When I try to run a simulation using ADE L, it says "the spectre executable you are using is an older version.Use MMSIM70 or a later version of this release".
    I'm using  spectre 7.0.0 and IC6.1.1.064. I have set the required environment variables for MMSIM70. How do I fix this?
    Vignesh
  • haikom
    haikom over 17 years ago
    the first orccurence of spectre executable in the environment variable PATH will be used. So in your case, please check whether the spectre executable inside the MMSIM7.0 path is defined before any other spectre executable.
    Regards
    haikom
