  3. Problem with the command.
  • Views 15082
NeSaM
NeSaM over 18 years ago
I'm using Virtuoso Layout Editor to draw the layout. I can create new things but i can't edit it.I can't use a few commands like delete,move,stretch,undo,redo and many more.Can anyone help me??
  • dmay
    dmay over 17 years ago
    You'll need to provide more information. Can you cut and paste some of the CDS.log in a post so we can help you? If you can draw, you should be able to stretch, move, etc. Here are some things to check:
    • Are all your layers selectable in the LSW?
    • Are you paying attention to the prompts in the bottom left corner of the Layout Editor window? This will tell you if you need to select an item or specify a reference point or a destination point.
    • Are there errors or warnings in the CIW?
    -Derek
