  3. What does this Ocean Error Mean
  • Views 15437
jayxgr81
jayxgr81 over 17 years ago
  I receive an error message says “branch distance too far in the generated code” and the ocean terminates my script without running any simulations.
All I had done was add some more expressions to evaluate, is there a way around this?
  • EricCDN
    EricCDN over 17 years ago
    In the past, this error came when a SKILL limit was reached.
    Typically, it was caused by having many "plot" commands nested.
    If you remove the commands, the error should go away.
  • jayxgr81
     Is there a way to get around this other then deleting plots or expressions that need to be evaluated?
