  3. Create spectre netlist using ocean (outwith icfb)
  • Views 16799
coco009
coco009 over 17 years ago
I would like to find a method of generating spectre netlists using a script, preferably an Ocean script.
At present, I have a pile of schematics, which do not have netlists. I can create netlists by running up the ADE GUI (which automatically creates a netlist on startup), but ideally I want to avoid running up ADE at all and do all my work from the command line, i.e. within Ocean
Essentially, I want to run the Ocean command 'design( "myLib" "myDesign" "schematic")' from the Ocean command line, but it appears this can only be done when within icfb, otherwise a specific netlist/file must be specified.
Does anybody know of a way around this?
Thanks very much in advance!
Regards
coco009
  • aplumb
    aplumb over 17 years ago
     There's no getting around needing to run icfb (versus ocean) to generate the netlist, however you can use the '-nograph' option to run things strictly from the command-line, e.g.'icfb -nograph'.
     Aside: If you have a mix of ADE L, XL and GXL licenses you may need to add the following to your .cdsenv to get it to automagically check out the next tier license if no L-tier are available:
    designEditor.license appsWhichAlwaysTryHigherTieredLicense string "ADE L,ADE XL"
    It took me weeks to figure out that was why our ocean and -nograph sessions wouldn't run for any apparent reason.  All the L-tier licenses were checked out and it was waiting for a response from an invisible 'Do you want to check out next tier licenses?' prompt.
    Hope this helps!
  • aplumb
    ...and just for reference, there is the following line in the IC5.1.4.1 version of the OCEAN Reference description for 'design':
    Note:  You can use the lib, cell, view version of the design command only if you are running OCEAN within icms, msfb, or icfb. You cannot use this version of the command within the OCEAN process itself.
     A.
  • skillUser
    skillUser over 17 years ago
     Andrew is correct, you would need to use "icms" or "icfb" etc. in order to be able to netlist a design using the OCEAN design() command.
  • coco009
    Thanks again for your help.
    It is never easy is it?! I noticed the fact that you cannot always use design( lib design cellview) just after my previous post, so this explains why it does not work directly from ocean.
    I will try the -nograph option and failing that, I'll just have to create all the netlists up front and then use Ocean to do the test scripts after that.
    Regards
    coco009
  • coco009
    Thanks also skillUser! Comments much appreciated!
