  3. Is there a voltage probe symbol for analog lib?
  • Subscribers 132
  • Views 17327
Milkman
Milkman over 17 years ago
Designers want a voltage probe that can be instantiated on a schematic.  The voltage probe translates to a .probe statement in hspice netlists or a save netname statement in a spectre netlist.
Here are my questions
1.Do I need to use a formInitProc to get the attached netname or a callback procedure?
2. In the formInitProc or Callback proc, how do I get the value of the netname attached to the terminal?
 Here are the code fragments below.
;; netlist procedure to print save netname line in spectre netlist
;; procedure( sgSpectreVprobe(inst)
    let((fp net_name enable complete_line cv)
    fp=nlGetNetlister(inst)
;; Get value from instance
    net_name = nlGetParamStringValue(inst 'net_name)
    ;cv = nlGetCurrentCellView(inst)
    ;l_nets = nlGetSimTerminalNets(cv)
    ;this_net=car(l_nets)
    enable = nlGetParamStringValue(inst 'enable)
    complete_line = strcat("save net_name")
    nlPrintString(fp)
    nlPrintString(fp complete_line)
    ); let
);procedure
############# CDF pararmeter
    cdfCreateParam( cdfId
        ?name           "net_name"
        ?prompt         "net_name"
        ?defValue       "net_name"
        ?type           "string"
  • aplumb
    aplumb over 17 years ago
    I took a different approach and created a 'voltage bsource' device that could be instantiated in a schematic.  A designer can then set the 'v' parameter value to the anything, including simple v(path.to.internal.net) or differential signal expressions.  Then you assign a top-level net name to the bsource output and save as you see fit.
     I created a one-liner model file include to 'save all top-level signals' that designers can quickly enable:
    save * depth=1
    Not precisely what you're looking for, but may be useful if you can't get the vprobe working.
