  3. Ocean: Save waveforms to .png
  • Replies 7
  • Views 18428
coco009
coco009 over 17 years ago
I have a quick question and would be very grateful for some help.
I have an ocean script testbench, which is creating various plots. At the end of the run, I wish to save the resulting waveforms. Currently, I have to manually go: 'File' -> 'Save as image' on the waveform window. Could somebody please inform me how to do this within ocean, i.e as a script so that I can automate this? Any help would be greatly appreciated.
Regards
coco009
    archive over 17 years ago
     After plotting use the hardCopy function:
    hardCopyOptions(?hcOutputFile "myGraph.png")
    hardCopy()
    Samir Jafferali
  • coco009
    Dear Samir,
    Thanks for your very prompt reply. I knew it had to be something simple. I currently cant get it quite to work though, as I dont appear to have .cdsplotinit file. I have copied a sample file into the same locations as my .cdsinit file, but when plotting, I keep getting the error that there were no .cdsplotinit files found.
    Do you (or anyone else) know how to set up the .cdsplotinit file so that it will be picked up when I run the ocean script?
    Thanks very much again
    Regards
    coco009
  • coco009
    Hi again,
    Following on from my previous post, I have actually found that all I have to do is drop the .cdsplotinit file into my home directory and that works fine in that I am no longer warned that the file cant be found and it loads the one in my home directory.
    The problem now is that although the printing to file appears to have taken place ... no warnings/errors, there is no resulting .png file.
    Anybody have any thoughts? Is there something specific required within the .cdsplotinit file to perform the plotting of the .png?
    Thanks in advance
    coco009
  • coco009
    All sorted now!
    Thanks all for your help, particularly Samir!
    Regards
    coco009
  • bobbygang
    bobbygang over 15 years ago
    Hi, I'm new.
    I wrote a new post yesterday but I can't find it in forum until now so I write it here.
    I have similar question  of command "hardCopy".
    I wonder why I can't find the graph in the folder "zzz" after I set  hardCopyOptions(?hcTmpDir "/aaa/yyy/zzz") .
    I only can get the graph when I set  hardCopyOptions(?hcTmpDir "/aaa") .
    At first I think it  must be in root folder, but  I also can't get the graph when I set  hardCopyOptions(?hcTmpDir "/bbb") .
    Is there some requirement to the directory ?
  • swdesigner
    swdesigner over 13 years ago
    Is it possible to plot waveforms to a "virtual" waveform window and then capture that window to a JPG or PNG? That would be useful for batch mode.
  • swdesigner
    Seems like
    > ocean -nograph
    makes this possible..
