  3. Process Corners set up problem
  • Views 15396
Marke
Marke over 17 years ago
Basically I know how to set up a process corners for multiple model library, however some fab provide model files which include several
 different device sections in one file. For example, there is a model file "mos.scs" which include sections like "tt", "ss", "ff",  "tt_25",
 "ss_25", and "ff_25" for .13um and .25um devices, then I should define "mos.scs" twice in the process corner. After I save the set up,
I find the later define will overwrite the previous one. One solution is to have different files for different devices, but I do not want to change
the model files.
Is there another way to set up the process corners?
Thanks in advance if anyone could give some advice.
