  3. IC5.1.41 distributed processing copyMode problem
  • Views 14360
benlau
benlau over 17 years ago
Hello gentlemen,
I am new user and I am not sure into which forum this should go, so I selected this one :)
Recently I've been trying to setup distributed processing environment. It seams everything is working ok: DP setup check finishes without errors, simulations run and finishes. So I am almost done except one tiny problem, which occurs when in .cdsenv file I use
asimenv.distributed     copyMode        boolean  t
i.e. copy mode is enabled instead of the network mode. Simulations run (I tried parametric analysis) just fine, it finishes without errors. However I can't access the results. I dug deeper into file system, where my simulation data is stored and found some differences how the data is stored. From documentation I found it should be located as follows:
<base_dir>/param/jobxxx/<var=value1>/psf/files
But in my case some files are really in this dir:
artistLogFile
runObjFile
simRunData
variables_file
But other files (logs and simulation data itself) are in the following dir:
<base_dir>/param/jobxxx/<var=value1>/psf/psf/files
From where this additional /psf/ comes? If I move the files from .../psf/psf/files to .../psf/files the results are displayed just fine...
In network mode there is no such problem, everything is ok.
One additional remark. I use ssh and scp instead of rsh and rcp, i.e. I just replaced the binary rsh and rcp with the links to ssh and scp in /usr/bin/. This is a workaround, because in this version (IC5.1.41) it is not possible to use ssh and scp by cadence means, I only found in IC6.1.3 the variable “asimenv.distributed remoteShell” where is possible select between rsh and ssh (rcp and scp respectively). Although I am not quite sure if scp (instead of rcp) is the reason for strange behavior, because scp is (or should be, if I read the man pages right) back compatible with rcp.
Conclusions. With current situation I have I would like to keep ssh/scp for security reasons; use copy mode, because network mode may require redesign of current network/CAD setup; use IC5.1.41 to minimize changes to CAD environment; avoid using additional scripts for copying data into the right place.
If anyone got some clue, please let me know.
Regards
benlau
P.S.
OS – RedHat linux ES 4 & 5
Cadence Tools – IC5.1.41
