  3. Simulating "streamed-in" gds files
  • Views 2116
Sirrius
Sirrius over 17 years ago
Hello All,
I have "streamed-in" a gds file, and would like to simulate the design. I extract the parasitics, and in the extracted file, I "attach labels" and "created pins from labels". When I try to create a netlist, I get an error that effectively tells me that it the design was changed since the time it was extracted". Therefore, I tried "attaching labels" and then "creating pins from labels" before parasitic extraction. But, this time, the parasitic extraction fails, after telling me that there are too many pWell and pBulk layers on the labels.
 Can someone please let me know how to simulate the streamed-in designs from a gds file?
 Would really appreciate some clues.
Thanks and Regards
Sirrius
  • aplumb
    aplumb over 17 years ago
     You're on the right track.  This is what works for me:
    1. Stream in the GDS
    2. Create Pins from Labels - make sure you only select text found where you expect them to be explicitly wired up, e.g. M1:pin, M2:drawing, etc. (bulk connections are usually implicit connections so you probably don't want pins showing up there)
    3. Create the extracted rep - the pins and connectivity should exist in the correct places.
    Hope this helps!
  • Sirrius
    Hello Andrew,
    Thanks a lot for your inputs. I have been able to simulate my layouts!
    Wish you a wonderful new year 2009!
    Regards
