  3. SOC Encounter: Problem with multiple clocks
  • Views 15479
Sirrius
Sirrius over 17 years ago
 Hello All,
 I have a design that involves two clocks (clk and sh_clk). However, after encounter synthesizes my design, it "splits" my clocks.
The design consists of a kernel (Braun_Multiplier) and a wrapper for pads (Braun_Multiplier_WithPads), The input design header for the core reads:
module Braun_Multiplier(A_in, B_in, clk, sh_clk, clear, mult_output, cmp_out);
While the header for the core in the nelist generated by Encounter reads:
 module Braun_Multiplier (
    A_in,
    B_in,
    clk,
    sh_clk,
    clear,
    mult_output,
    cmp_out,
    clk_at_Pad__L2_N1,
    clk_at_Pad__L2_N2,
    clk_at_Pad__L2_N3 );
 I do not understand why the clk signal should be "split" like shown here. I am not sure whether this is correct or not.
 However, at the highest level of design (Braun_Multiplier_WithPads), the input design header to Enounter is:
module Braun_Multiplier_WithPads(A_ChipInp, B_ChipInp, clk_ChipInp,
     sh_clk_ChipInp, clear_ChipInp, mult_output_ChipOutp,
     cmp_out_ChipOutp);
 and in the netlist generated by Encounter, it is:
module Braun_Multiplier_WithPads (
    A_ChipInp,
    B_ChipInp,
    clk_ChipInp,
    sh_clk_ChipInp,
    clear_ChipInp,
    cmp_out_ChipOutp );
So, there seems to be consistency here.
In my synthesis script for Encounter, I have these lines:
setClockDomains -all \
  -clk clk sh_clk\
  -event R
 Can someone please point out to me whether this may be a problem? And if yes, what step will rectify it?
I wanted to attach the entire script that I use for synthesis, but, couldn't find "attach" option :(
Sirrius
  • Austin CAD Guy
    Austin CAD Guy over 17 years ago
    This is the Custom IC (Virtuoso) forum and you will probably do better by posting this in the digital forum.
  • Sirrius
    Done! Thanks for the suggestion
