  3. Ocean script plot question
  • Replies 7
  • Subscribers 133
  • Views 17553
Pudzian
Pudzian over 17 years ago
 I am ploting my data from an array in a for loop:
 for ( i 0 2
            plot(i_ref[i])
This is okay, but is there a way to also inlude the waveform names in an array so they get displayed instead of the default name?  Maybe there is a better way to do this?  I would appreciate any suggestions.
Thanks.
  • skillUser
    skillUser over 17 years ago
    One of my colleagues wrote the following, which may not work due to a bug, depending on the version, in which case, the second version should provide a solution instead:
    procedure(CCSPlotNets(nets)
       let((waves)
         waves=foreach(mapcar net nets v(net))
         apply('plot append(waves list(?expr nets)))
    ) ; let
    ) ; CCSPlotNets
    procedure(CCSPlotNets2(nets)
    let((waves)
        graphicsOff()
        foreach(net nets
            plot(v(net) ?expr list(net))
            ) ; foreach
        graphicsOn()
        ) ; let
    ) ; CCSPlotNets2
    Hope it helps!
    Lawrence.
  • jerry124
    jerry124 over 12 years ago
    I would like to plot graph in a for loop like
    for (corno 1 10
    aa=sprintf(nil "%d" corno)
    cc=strcat("sci" aa "-tran")
    plot(getData("d1" ?result cc))
    This plot doesnt work, but it works if I write:
    plot(getData("d1" ?result "sci01-tran"))
    Does anyone have suggestion how to run plot with variable in the loop?
    jerry
  • skillUser
    skillUser over 12 years ago
    Hi Jerry,
    In your example you try to plot "cc" but I don't see it defined; the line above uses "bb", try that, it looks like it should work...
    By the way - please do not append to a really old thread (please read the Guidelines), it is more sensible to start a new thread.
    Lawrence.
  • jerry124
    Hi Lawrence,
    thank you for quick reply. Yes there is typing mistake. it should be “cc” instead of “bb” (I edit in post above), but this doesn’t work:
    ERROR (WIA-1006): Unable to plot expression <getData("d1" ?result cc)>
              because it does not evaluate to an object that can be plotted, like a waveform or
              parametric wave. See the Visualization & Analysis Tool documentation for information
              about the types of objects that can be plotted in Visualization & Analysis Tool. Only
               the expressions that evaluate to those objects can be plotted.
    Jerry
  • skillUser
    Hi Jerry,
    Have you tried building this expression in the CIW and testing it?  Doing this step by step in the CIW may reveal an issue in either the result name, or what getData() returns etc.
    Start a new thread for further discussion on this issue, include the version that you are using.
    Lawrence.
    What does results() and results(?noAlias t) return?
  • jerry124
    I start new tread for this discussion:
    /forums/p/27663/1328315.aspx#1328315
    BR
    Jerry
