  3. Assura DRC: How to Define derived layers
  • Views 18169
stuso
stuso over 17 years ago
Hi there,
I'm wondering how you define your own variables/derived layers, e.g when i'm using this
command:
    newVia2_a = geomSize( VIA2 0.07 )
However Assura doesn't seem to like that i have not deifined "newVia2_a".
Can someone tell me the syntax to do this, i'm assuming it has to go in the  layerDefs section somehow.
Stu
  • skillUser
    skillUser over 17 years ago
    Hi Stu,
    I don't work with Assura myself, but a few of my colleagues have stated that there does not appear to be any issue with the line of code as it is, but:
    1) Ensure that the statement is in the Rules section, not in the layerDefs section
    2) Ensure that the preceeding statement(s) do not have any errors
    One of my colleagues supplied the following sample rules file:
    drcExtractRules(
    layerDefs( "df2"
    VIA2 = layer( "VIA2" )
    );end df2 layerDefs section
    layerDefs( "gds2"
    VIA2 = layer( 14 )
    );end gds2 layerDefs section
    errorLayer( newVia2_a "Enlarged VIA2" )
    );end drcExtractRules
    This compiles correctly.
    I hope that the above information helps you, if not, you may need to send us your rules file for further assistance.
    Lawrence.
  • stuso
    Hi Lawrence, it was indeed an error in a preceeding statement, thanks for your help.
    Cheers
    Stu
  • stuso
    Hi Lawrence,
    can you(or anyone out there) please ask the Assura guys if you cannot perform geomAnd on derived layers, so for example this would not work:
     drcExtractRules(
    layerDefs( "df2"
          OD          = layer( "OD" )
    ); end df2 layerDefs
        OD_1         = geomSize( OD 0.005 )
        OD_2        = geomAnd( OD_1 )
        saveDerived( OD_2 "TESTING OD_2 ")
    This fails with:
     error:  No such original or unmerged layer 'OD_1'.
    When  i change the geomAnd to geomOr the code compiles (though of course its not what i want functionally).
    I read in the assura manual regarding geomAnd:
    " Description
    Generates new shapes from the overlap of original shapes on the input layers."
    So this perhaps infers that you indeed cannot geomAnd derived shapes?
    Cheers
    Stu
    Andrew Beckett over 17 years ago
    Stu,
    You can of course use geomAnd on derived layers, but in this case you are trying to use geomAnd with a single layer - normally it would be done geomAnd(layer1 layer2) for example.
    If you want to use the single-layer form of geomAnd, that means you're trying to do a selfLayer and - to quote the geomAnd documentation it says:
    A selfAnd operation is performed by providing a single unmerged layer as input. An unmerged polygon layer is either an original graphics layer or the unmerged output of a geomSize command (see "geomSize").
    A self-and means that it will and the shapes with shapes from the same layer - that only makes sense if the data is unmerged, because otherwise you'll always get nothing.
    So what you'd do so:
        OD_1         = geomSize( OD 0.005 unmerged )
    Note the "unmerged" keyword in the geomSize function. If you do this, it will find any gaps less than 0.01 wide between OD and other OD, or any self-overlapping bits of OD. Whether that is what you really want, I don't know...
  • stuso
    Hi Andrew, thanks for the indepth reply, it was very useful.
    Stuart
