  3. ocean problem &ocnPrint!
  • Subscribers 133
  • Views 1943
FormerMember
FormerMember over 17 years ago
I write ocean script for parameter analysis and use ocnPrint to print some simulation result.
For example:
fp=outfile( "./paramResults.out" "a" )
risetime_netA=riseTime(clip(VT("/C5") 5e-08 9e-08) 0 nil VAR("core_voltage") nil 10 90)*1e09
ocnPrint(?output fp ?numSpaces 2 ?width 12 )
After the simulation, the results in the file "paramResults.out" as following:
xxx  xxx  xxx  xxx  xxx  xxx
How can I get the results as following,use the "expression name" to replace the "expreesion"?  And also add some comments automatically at the end or begin of the results.
risetime_netA
; comment
The other question is how to write a script to run paramatic analysis and corner analysis at the same time!!
Thanks in advance!!
    archive over 17 years ago
      You cannot customize what ocnPrint will write.  However, since you are arlready using file ports, you can print your expression name and comments both before and after your ocnPrint command using fprintf.  When using ports always remember to close them with close().
     Samir Jafferali
  • FormerMember
    Thanks for your reply.
    BTW , how to write a script to run corner analysis for paramatric analysis?
