  3. Creating auto calculating form where form fields are getting...
  • Views 15010
Creating auto calculating form where form fields are getting calculated in the form itself
AmitBiswas
AmitBiswas over 17 years ago
I wan to create a form where some of the form fields will be automatically evaluated depending upon the other form field value.suppose metal width is one form field and I want to calculate no. of row of via , will be calculated taking care of DRC in the form itself so that user can take a descision before proceeding further.All the calculation I will do but how to reflect the result of the calculation in the form itself.one example like during instantiating a resistor if width is independent variable, length will be calculated depending upon the vale of the resistor.If anybody knows, please help.
  • Austin CAD Guy
    Austin CAD Guy over 17 years ago
     Fields have series of callbacks which execute when the focus is changed to the field (?focusInCallback), when the value is modified (?modifyCallback) and when the field looses focus (?callback). If the callbacks are strings, they must be complete SKILL expressions, if they are a symbol, they are a function and will be called with a set number of arguments.
    The documentation is in the Cadence User Interface SKILL Reference manual.
