  3. Interpreted label on instance [error]
  • Views 15287
moore
moore over 17 years ago
hi, Please tell me the solution of this error. The interpreted label on instance will be disappeared occasionally when fitting or resizing current schematic window in composer. and the CIW shows the warning info: *WARNING* ilMakeString: NULL String, changed to "". Thank you for your advice!
  • skillUser
    skillUser over 17 years ago
    Which version are you using? Do the symbols use a custom SKILL label?  Are you displaying (back annotating) simulation results in the schematic, and if so, was it the schematic that you simulated with, or a different view?
    This message has arisen in a few different tools and places, so more information would be needed to help track the cause or reason in this case.
    Lawrence.
  • moore
    Hi, The version is IC51. And the symbols use the SKILL label(ex: iPar(arg) etc., arg is defined in CDF). There is no simulation operation, only the schematic edit. Maybe there is sth wrong about the arg inherited from the CDF defined parameters? I guess. Regards, Moore.
