  3. dbLayerTile need help
  • Replies 12
  • Views 20839
lrl1skdev
lrl1skdev over 17 years ago
Hi everyone,
 I am writing a code where i needed to fracture layers vertically and horiontally. I used dbLayerTile to fracture them vertically and I created my own version that fracture layers horiontally since I could not find anything in the documantation that do this job. My problem is I wanted to boost the performance of the code so my first thought is to rotate them by 90deg and then execute dbLayerTile a second time then bring them altogether to their original position. But how to write this in a code in a simplest way still puzzles me.
Any suggestions?
  • prandi
    prandi over 13 years ago
    Andrew,
    Thanks a lot for the constant help and support since morning. One last issue: active is getting formed on the extended polys..
    I used the command chk=dbLayerSize(cv "POLY" list(gate) 0.0005)
    and did dbLayerAnd(cv :POLY"  list(chk) list(gate))
    then dbDeleteObject(gate)
    On the final extended poly,active is getting formed...
    The code you've posted would appear to me to oversize the gates a little (by 0.5nm), and then and those shapes with the original gate, and then delete the original gate. The result of the dbLayerAnd would be the same as the original gates, so I can't see what you're doing here. You'd have both the oversized gates and copy of the gates (the result of the And). I can't see how "active is being formed" since there's no mention of active here.
    Your code doesn't look correct from what you've posted - but I suspect it's only a small bit of the code and not enough detail for anyone to figure out what you're doing.
