  3. ocnprint
  • Views 15274
ocnprint
leongec
leongec over 17 years ago
 hi all , i have one question regarding to the ocnprint. the following is my script
f1=1
f2=2
f3=3
q1=4
q2=5
q3=6
ocnPrint(?output "/home/result.txt"  f1,q1)
ocnPrint(?output "/home/result.txt"  f2,q2)
ocnPrint(?output "/home/result.txt"  f3,q3)
i would like to print the f2 and q2 in the next line of f1 and q1, but i realize that the latest print will replace the older one, how can i use the "append" command to fix my problem??
thank you for your advice:)
  • Bernd
    Bernd over 17 years ago
    p_port = outfile( t_fileName "a" )
    ocnPrint( ?output p_port ... ) ;; fisrt ocnPrint
    ocnPrint( ?output p_port ... ) ;; second ocnPrint
    close( p_port )
  • leongec
     hi Bernd, thanks for your help!
    I can make it now ^_^
