  3. Ocean plot in specific window
  • Views 15277
Pudzian
Pudzian over 17 years ago
 How can I plot in a specific window or subwindow once it has been opened?
  • skillUser
    skillUser over 17 years ago
    If you use a function like newWindow() to open the window, it returns the window id - store this in a variable and then you can make this window current for plotting using currentWindow() at a later time so that plots would go to that window. There are similar commands for subwindows too, addSubwindow() and currentSubwindow().
    This should answer your question I think.
    Lawrence.
