  3. Ultrasim parasitics spf file format for backannotation
  • Views 16666
Geser
Geser over 17 years ago
Hi all.
 I have some problem with spf files. I want to do post-layout simulation with ultrasim. It is option in ultrasim to supply spf file with extraction information for backannotation. I have spf file I got from StarRCXT(synopsis extraction tool). But when I am trying to do simulation with this file, lot of errors occuring at the file parsing stage. Seems like my SPF file have format is different from format expected by UltraSim parser.
So, the question is where I can read explanation about syntax of SPF file, as it needed for UltraSim parser? May be it is some example somwhere?
Thanks!
  • EricCDN
    EricCDN over 17 years ago
    Please see:
     $MMSIMHOME/tools/ultrasim/examples/Ultrasim_Workshop/post_layout
  • Geser
    Thanks EricCDN,
    it was very usefull.
    But i still have one problem. It is not use of transistor multiplyer in this example.THe extractor creates multiple transistor in extraction netlist. But it need to be coresponding to single transistor in schematic. So, what is the syntax in extracted netlist to say that multiple transistors is same transistor with multiplyer in schematic netlist?
    Best regards,
    Alex
