  3. why I can't use QRC to extract RC
  • Views 1204
MIPSABG
MIPSABG over 17 years ago
I'm using soc8.1 now, and when I use runQRC,I will get following errors.
Is that because we didn't install QRC after the soc encounter's installation? if I'm right,where can I find the package for QRC?
otherwise,what's the problem?
runQRC -libraryName library -techFile qrcTechFile -outputFileName qrc.spef
Writing DEF file '.qx.def', current time is Mon Feb 23 16:01:23 2009 ...
unitPerMicron=2000, dbgMicronPerDBU=0.000500, unitPerDBU=1.000000
DEF file '.qx.def' is written, current time is Mon Feb 23 16:01:23 2009 ...
"qrc" failed to finish successfully.
**ERROR: (SOCEXT-5016): qrc failed due to failed to run qrcfailed to run: Unknown error 200Failed to run qrc - Please call cadence support..
Thanks a lot for your reply!
  • aplumb
    aplumb over 17 years ago
    Depending on what the foundry has QA'd and provided in the way of rule decks, you'll want to install either EXT7.1.2 or EXT8.1.1. Andrew.
