  3. ASSURA DRC ERROR
  • Views 15601
ASSURA DRC ERROR
Ling
Ling over 17 years ago
Hi,all
I met a problem. When I run DRC with ASSURA, an error happened as following:
*Error* parseString: argument #1 should be either a string or a symbol (type template = "SS") - nil
It seems that I am missing a parameter, but I don't know where to define this parameter. I know when running
ASSURA DRC, the function vuiDRCRun() will be called, but which file defines this function? What's wrong with this function?
Ungently for your help!
Thank you very much!
Ling
  • Ling
    Hi ,all
    I knew the reason, beacuse my .drc.Last.state file is empty.When I remove this file, ASSURA DRC works well.
    but I still don't know where the vuiDRCRun() function defined? Can anyone tell me about this?
    Thanks!
    Ling
