  3. How do I automatically load bindkeys every time I open Virtuoso...
  • Subscribers 139
  • Views 28210
How do I automatically load bindkeys every time I open Virtuoso?
Unicode787Plus
Unicode787Plus over 17 years ago
For some reason, whenever I open Virtuoso in my school's UNIX/Linux account, bindkeys are not automatically enabled (except Esc to cancel a command). My only manual workaround is by typing the following on the CIW:
load(prependInstallPath("samples/local/leBindKeys.il"))
How do I set up my account to automatically load bindkeys?
    archive over 17 years ago
    You can set commands to run automatically by creating a .cdsinit file, as described in <install_dir>/doc/dfIIconfig/dfIIconfig.pdf
    Essentially, just add the line to .cdsinit in your home directory or the current directory.
    Cheers,
     Roger
  • stuso
    stuso over 17 years ago
    Hi there,
    Are you using the sample cdsinit file from cadence? If you open your the equivalent of this file:
     ...../IC06.13.507/tools.lnx86/dfII/samples/local/cdsinit and search for bindKey you will find it should be referenced.
    If i remember correctly the first place cadence will look for a .cdsinit will be:
     IC06.13.507/tools.lnx86/dfII/local
    Do you have such a directory, i suspect you do not or it is empty? I had to create mine and then copy the sample cdsinit to .cdsinit, for example:
    cd  /IC06.13.507/tools/dfII
    mkdir local
    cd local
    cp  /IC06.13.507/tools.lnx86/dfII/samples/local/cdsinit .cdsinit
    Note that you can still have your own .cdsinit & .cdsenv in your working area to setup your own particular preferences.
    Hope this helps
    Stu
  • skillUser
    skillUser over 17 years ago
     I will add to what Stu has said. The first .cdsinit file found by the search mechanism causes that file to be loaded and the search stops, so no more .cdsinit files would be automatically loaded.  However, the samples/local/.cdsinit file could contain SKILL code to load further .cdsinit files, if present. For example:
      when(isFile("~/.cdsinit")
        load("~/.cdsinit")
     The .cdsenv files follow a slightly different search methodology in that any files found on the search path will be loaded.  Additionally the environment variable CDS_LOAD_ENV can help to control which, if any, .cdsenv files are loaded, with values like addCWD, CSF, CWD, False, and CWDElseHome. The CSF setting instructs to use the Cadence Search File mechanism.
     I hope that this helps you to set up your environment!
    Lawrence.
  • Deepon Saha
    Deepon Saha over 15 years ago
    Thanks Austin,
    That reply of yours solved lot of my queries. Helped me a lot in designing a shell script..:)
    Kolkata,
    Austin is where "skillUser" is located. Not his name ;-)
    I've seen a few people making this mistake (as I did intentionally in this reply).
    Andrew (I'm called Andrew, not Bracknell)
  • Deepon Saha
    Bracknel,
    Thanks for pointing it out.. ;)
