  3. Shell commands in an OCEAN script
  • Views 17319
Ueue
Ueue over 17 years ago
Dear all,
 I would like to execute shell commands in an OCEAN script. For example removing files in order to increase the space on the disk between a simulation and the next. Is it possible?
 Thanks in advance.
    archive over 17 years ago
     Try the sh, shell, or system commands as documented in <cds dir>/doc/sklangref/sklangref.pdf
     Cheers,
     Roger
  • skillUser
    skillUser over 17 years ago
    While Roger is correct, there are also built-in SKILL commands for accessing the filesystem and in cases such as this it would be better to use those instead, for example:
    when(isFile("myFileToDelete")
       deleteFile("myFileToDelete")
    ); when
    Other commands that may be useful include getDirFiles(), fileTimeModified(), isFileName(), makeTempFileName() and getTempDir().
    Hope this helps you!
    Lawrence.
  • skillUser
    I forgot another very useful command: getWorkingDir().
    Also there are isDir(), createDir() and deleteDir().
    Lawrence.
